[rebel-builders] fiberglass question
mbetti
Post by mbetti » Sun Feb 19, 2012 11:12 am
That is a high build primer surfacer for fiberglass. You spray on a couple coats and then wet sand it smooth, repeat as necessary.
Mike Betti
771E
On Tue, 26 Sep 2006 02:19:08 -0700 (PDT), rebel-builders@dcsol.com said:
Greetings folks,
I am now learning how to fiberglass. I will soon take
on the glassing of my windshield retainer. From
studying some of the pics on other builders websites,
most seem to have a nice smooth finish (light blue in
color). Is this just the epoxy resin sanded down, or
is there some sort of final top coat that you apply
that gives the smooth finish surface?
Thanks, -Jason
SR131
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
S A
Post by S A » Sun Feb 19, 2012 11:12 am
Before the primer I used Polyfiber "SuperFil" light weight epoxy filler
(same stuff I filled my rivet heads with) that is the blue stuff on mine
anyway. http://www.aircraftspruce.com/catalog/c ... perfil.php
FWIW
Scott
Mike Betti
771E
Greetings folks,
Thanks, -Jason
SR131
Do You Yahoo!?
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 11:12 am
Jason,
For a much more pleasant experience use epoxy resin for laying up the glass,
and filling the voids in the finishing stage. You can get different
densities of fillers to mix with the resin to make light, sandable "putty".
Epoxy is WAY friendlier to work with than stinky pollyester.
Jesse
Subject: Re: [rebel-builders] fiberglass question
Date: Tue, 26 Sep 2006 10:08:38 -0600
FWIW
Scott
couple
Mike Betti
771E
Greetings folks,
Thanks, -Jason
SR131
Do You Yahoo!?
