Just an update and small question on Proseal
Posted: Fri Feb 17, 2012 8:45 pm
I am working on Rebel 300. The fuselage was done when I got it and the
right wing was started. I am just about ready to Proseal the tank. I
remember a couple people suggesting that an 8:1 mix was better than 10:1
- any strong opinions about that? I plan to use a cake decorating bag
to hold the mix and squeeze it out as I go. I'll use tongue depressors
to fillet it into the corners and dip each tank rivet. I plan to keep
the temperature about 75 degrees F in the garage. Any other thoughts or
comments are appreciated. Gosh, I can't wait to fly this thing.
Best Regards,
Scott Hibbs
hibbs@pacifier.com
Best Regards,
Scott Hibbs
hibbs@pacifier.com
