[rebel-builders] Rudder Trim Tab
Robert and Olga Johnson
Post by Robert and Olga Johnson » Sun Feb 19, 2012 11:07 am
Hi Rich: I never added one to my Rebel (652) and did not need it either.
There was the normal tendency to turn left (O320) in cruise, but I corrected
that by increasing the spring tension on the right rudder pedal. Simple and
effective. I still needed additional right rudder on take off but that is
normal anyway. The only way around that is an electric or adjustable trim on
the rudder, but personally I do not like playing with trim all the time -
that's what flying is all about - YOU controlling the airplane in it's
various flying configurations. That's MHO. - Bob J Rebel 192/731
To: "Rebel Listserve" <rebel-builders@dcsol.com>
Sent: Tuesday, August 29, 2006 6:34 PM
Subject: [rebel-builders] Rudder Trim Tab
Gents,
I am moving along on the rudder construction. Just about have it all
drilled and getting ready to preserve it before assembly. Thanks for the
tips! I believe I have managed to deconflict my rivet spacing on the end
caps
I noticed on Deiter's very nice online builder's log that he attached a
trim tab (the good old fashioned manual type - just bend it to suit) to
the trailing edge. It looks good. Before I go ahead and fabricate one of
those, I was wondering what the opinion was from the more experienced
Rebel crowd.
Is it necessary? Nice to have? Or simply "a good thing" as Martha
Stewart would say?
Thanks for the help!
Rich Dodson
Virginia Beach, VA
Rebel 806R
Post by Walter Klatt » Sun Feb 19, 2012 11:07 am
Rich, I would wait until you are flying before deciding on rudder trim. I
don't have it on mine and don't need it. But I do have my vertical fin
offset.
While I have electric elevator trim, I never use it either. I could have got
away with just a fixed trim tab on the elevator. And if you mount your hor
stab as per Wayne's instructions (somewhere in the archives), you wouldn't
need that either. Unlike many airplanes, the Rebel doesn't require elevator
trim adjustments during different flight attitudes and speeds.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Robert
and Olga Johnson
Sent: August 29, 2006 6:01 PM
Subject: Re: [rebel-builders] Rudder Trim Tab
Gents,
caps
Rebel crowd.
Stewart would say?
Rich Dodson
Virginia Beach, VA
Rebel 806R
Garry Wright
Post by Garry Wright » Sun Feb 19, 2012 11:07 am
While I basically agree with Walter on the Rebel's lack of need for
elevator trim, I do find a need for it - not much - but with widely
varying loads, and big differences in airspeed, FOKM requires a small
amount of elevator trim to completely eliminate stick pressures. It does
this with both wheels and amphibs so it is sometimes necessary. I too do
not have any rudder trim. If one wanted to get away without the weight
of the trim system, one could probably do it with a fixed tab for most
flight regimes on FOKM too.
I may be overly sensitive to stick pressures having been weaned on a
plane with effective electric trims. I'm not sure I would put it on if I
did not have it.
Garry
offset.
and Olga Johnson
Gents,
caps
Rebel crowd.
Stewart would say?
Rich Dodson
Virginia Beach, VA
Rebel 806R
I think that c of g can vary more on wheels than on floats with different
loads, but agree that does affect elevator trim slightly and have noticed it
the odd time when I had a big load in back. Having said that, I can't
remember when I last used my elevator trim, probably not in the last year.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Garry
Wright
Sent: August 29, 2006 7:02 PM
Subject: RE: [rebel-builders] Rudder Trim Tab
did not have it.
Garry
offset.
got
elevator
Robert
and Olga Johnson
corrected
on
Gents,
end
caps
Rebel crowd.
Stewart would say?
Rich Dodson
Virginia Beach, VA
Rebel 806R
Post by Drew Dalgleish » Sun Feb 19, 2012 11:07 am
I use trim in flight depending on load and speed. It only takes a little
bit to get to fly hans off. I used to trim for approach speed to landing
but haven't bothered to do that for ages.
Wright
did not have it.
Garry
offset.
got
elevator
Robert
and Olga Johnson
corrected
on
Gents,
end
caps
Rebel crowd.
Stewart would say?
Rich Dodson
Virginia Beach, VA
Rebel 806R
