[rebel-builders] Inetcom question
steve whitenect
Post by steve whitenect » Sun Feb 19, 2012 11:04 am
Hi Mike
I have the Garmin SL-40 with the built in intercom and it worked flawlessly
to Osh and back. Can set mike levels seperately which I understand is
something u can't do with the Icom. Second plane in company with us has a
Icom and pilot said he'd not get another.
Steve W. 637R
Subject: [rebel-builders] Inetcom question
Date: Fri, 25 Aug 2006 07:05:28 -0800
Is anybody here using the built in intercom feature of an Icom A200?
Post by Mike Davis » Sun Feb 19, 2012 11:04 am
Thanks Steve, I'm thinking about buying a C-150, and it has an Icom in it...
but hooked up to the overhead speaker and hand mic. I worked on jets for to
many years in the Marines, I need a headset... so I was hoping somebody with
experience could tell me if built in intercom on the Icom is decent, then I
wouldn't have to buy an intercom.
Sent: Friday, August 25, 2006 10:47 AM
Subject: RE: [rebel-builders] Inetcom question
Hi Mike
flawlessly
Steve W. 637R
Ian Donaldson
Post by Ian Donaldson » Sun Feb 19, 2012 11:07 am
G'day Mike
I have the Icom A200 in my Rebel and it works flawlessly, and I use the
inbuilt intercom system.
The intercom system is a great feature and it does away with unnecessary
external systems. (Listening to music while I fly is just a distraction as
far as I am concerned!)
There are more than 90 planes at our field, and the Icom is by far the
preferred choice. That must say something!
I have combined my Icom with a set of Sennheiser noise reductions headsets
and it is one of the best investments that I have made. All those extraneous
noises just go away! With the Sennheisers the microphone outputs are
individually adjustable and of course the volume.
regards
Ian Donaldson
: Is anybody here using the built in intercom feature of an Icom A200?
: Mike
: List archives located at: https://www.dcsol.com/login
: username "rebel" password "builder"
: Unsubscribe: rebel-builders-unsubscribe@dcsol.com
: List administrator: mike.davis@dcsol.com
Post by Ken » Sun Feb 19, 2012 11:07 am
I know some guys have used it but I believe it is a push to talk type of
intercom. Leastwise I don't see any way to wire a VOX squelch adjustment
on my icom.
FWIW the hot mic with noise cancelling on my flightech intercom works
very well regardless of mic gain settings. I like it better than the VOX
type intercoms that I've used.
I don't understand why one would one want separate mic gain adjustments
on a radio? I'm slowly matching mic gains on the headsets so that all
headsets are interchangeable. The factory mic gain setting on my icom
was set way too high when I purchased it.
Hi Mike
flawlessly
Steve W. 637R
Post by Mike Kimball » Sun Feb 19, 2012 11:07 am
You don't have to buy an intercom either way. I've got a FlightCom 2-place
with extension box for two more that I won't be using.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]
Sent: Friday, August 25, 2006 10:53 AM
Subject: Re: [rebel-builders] Inetcom question
Hi Mike
flawlessly
Steve W. 637R
Post by Mike Davis » Sun Feb 19, 2012 11:07 am
Thanks Mike, that's definately an option, but I'll probably talk to Aircom
first about using the Icom... I've got to have at least one set of jacks
installed anyway since there aren't any.
Sent: Friday, August 25, 2006 6:03 PM
2-place
This is the impression I got from the information on Icom's web site... but
it really wasn't clear. That's why I asked here, I figured somebody would
be able to explain it. I'd prefer a VOX type setup, but could certainly
live with the push to talk... I'll probably spend most of my time in this
airplane solo anyway.
Sent: Friday, August 25, 2006 4:45 PM
on my icom.
Thanks Ian, can you verify whether this is a push to talk intercom? Their
web site really doesn't say anything, but I found a review that talked about
an operate/intercom switch.
Sent: Friday, August 25, 2006 4:12 PM
G'day Mike
as
extraneous
regards
Ian Donaldson
: Mike
Bill Maxwell
Post by Bill Maxwell » Sun Feb 19, 2012 11:07 am
The more common method is to wire the mics to the intercom connection on the
A200, such that he intercom is normally connected. Then, when PTT is
pressed, wire it such that the pilot's mic is switched from the intercom
connection to the coms connection.and if you like, simultaneously ground the
co-pilot mic. Best done with a DPDT relay but I have done two with a DPDT
push switch in the stick. Makes for a difficult job getting all the wires
run up through the stick. A relay, mounted remotely but triggered from the
PTT button in the stick, is a far better approach.
All that said and while it certainly works, it does mean the intercom is
'hot mic", or always on unless the PTT is pushed, rather than using a vox
switch. I have installed 5 of these radios that way but let me say, I think
a separate intercom is the way to go and that is what I am doing on my
aircraft.
It needs to be said that the wiring info on this aspect in the owner's
manual is not particulary useful and in the service manual it is no better.
It has led one common Australian aircraft, the Lightwing, to appear with a
separate toggle switches to control the radio/intercom operation, as well as
the PTT button. I dont know whether it was the factory approach or that of a
particular installer but I think it is a very clumsy approach. However, I
think they were led there by the diagram in the owner's manual.
Bill
753R----- Original Message -----
Sent: Saturday, August 26, 2006 2:05 PM
but
on my icom.
What! I gotta stay on the ground and watch you disappear in the distance?
044SR
Sent: Friday, August 25, 2006 8:05 PM
on my icom.
lol, I did't say all of the time, only most. You'll get your SR going soon
and then I'll be building time until you get your 40 hours flown off.
Sent: Saturday, August 26, 2006 7:32 PM
044SR
but
on my icom.
__________ NOD32 1.1727 (20060826) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
