[rebel-builders] fus 27
Robert and Olga Johnson
Post by Robert and Olga Johnson » Sun Feb 19, 2012 11:04 am
Hi Dave: I cannot find what your asking in my manuals. Can you be more
specific on section and step number so I can check. What you are saying does
not sound familiar. Bob J - Rebel192/731
Sent: Thursday, August 17, 2006 8:11 PM
Subject: [rebel-builders] fus 27
Can some one tell me ? as I seem to be not understanding this ! They tell
me
in the man, that the fus 27 top flange should be bent to a 45 of the web
do they mean the table ? I don't seem to be getting this section.
Thank you Dave T / rebel 009
Post by Ken » Sun Feb 19, 2012 11:04 am
It doesn't hurt to also remind us what a FUS-27 is ;) It seems it is
the fuselage rib above the door. (Fig 12.14.2) As far as I recall all
the flanges are 90 degrees on that. You do have to flute the top flange
to make the rib lie flat. Preferably with the flutes between where the
rivets will go. Don't forget to do the floatfix bulletin while working
in that area.
me
jimsrebel
Post by jimsrebel » Sun Feb 19, 2012 11:04 am
Cut the round hole for the cabin control tube first in aft part of FUS-27, then
plan the float fix doubler around the round hole.
On 8/18/2006 3:29 PM, klehman@albedo.net wrote to rebel-builders:
-> It doesn't hurt to also remind us what a FUS-27 is ;) It seems it is
-> the fuselage rib above the door. (Fig 12.14.2) As far as I recall all
-> the flanges are 90 degrees on that. You do have to flute the top flange
-> to make the rib lie flat. Preferably with the flutes between where the
-> rivets will go. Don't forget to do the floatfix bulletin while working
-> in that area.
-> Ken
-> Robert and Olga Johnson wrote:
-> >Hi Dave: I cannot find what your asking in my manuals. Can you be
more
-> >specific on section and step number so I can check. What you are
saying does
-> >not sound familiar. Bob J - Rebel192/731
-> >----- Original Message -----
-> >From: "David L. Tuck" <dltuck53@hotmail.com>
-> >To: <rebel-builders@dcsol.com>
-> >Sent: Thursday, August 17, 2006 8:11 PM
-> >Subject: [rebel-builders] fus 27
-> >>Can some one tell me ? as I seem to be not understanding this ! They
tell
-> >>me
-> >>in the man, that the fus 27 top flange should be bent to a 45 of the
web
-> >>do they mean the table ? I don't seem to be getting this section.
-> >>Thank you Dave T / rebel 009
apoulsen
Post by apoulsen » Sun Feb 19, 2012 11:04 am
Can the hole be located before the part is installed so I can use the hole
cutter in the drill press?
Allen Poulsen
Sent: Friday, August 18, 2006 9:02 PM
Subject: Re: [rebel-builders] fus 27
then
-> in that area.
-> Ken
more
saying does
tell
-> >>me
web
jimsrebel
Hold it up next to the wing root rib, then make a good guess.
On 8/18/2006 5:44 PM, apoulsen@comcast.net wrote to rebel-builders:
-> Can the hole be located before the part is installed so I can use the hole
-> cutter in the drill press?
-> Thanks,
-> Allen Poulsen
-> From: <jimsrebel@dcsol.com>
-> Sent: Friday, August 18, 2006 9:02 PM
-> Subject: Re: [rebel-builders] fus 27
-> > Cut the round hole for the cabin control tube first in aft part of FUS-27,
-> > then
-> > plan the float fix doubler around the round hole.
-> > On 8/18/2006 3:29 PM, klehman@albedo.net wrote to rebel-builders:
-> > -> It doesn't hurt to also remind us what a FUS-27 is ;) It seems it is
-> > -> the fuselage rib above the door. (Fig 12.14.2) As far as I recall all
-> > -> the flanges are 90 degrees on that. You do have to flute the top
flange
-> > -> to make the rib lie flat. Preferably with the flutes between where the
-> > -> rivets will go. Don't forget to do the floatfix bulletin while working
-> > -> in that area.
-> > -> Ken
-> > -> Robert and Olga Johnson wrote:
-> > -> >Hi Dave: I cannot find what your asking in my manuals. Can you
be
-> > more
-> > -> >specific on section and step number so I can check. What you are
-> > saying does
-> > -> >not sound familiar. Bob J - Rebel192/731
-> > -> >----- Original Message -----
-> > -> >From: "David L. Tuck" <dltuck53@hotmail.com>
-> > -> >To: <rebel-builders@dcsol.com>
-> > -> >Sent: Thursday, August 17, 2006 8:11 PM
-> > -> >Subject: [rebel-builders] fus 27
-> > -> >>Can some one tell me ? as I seem to be not understanding this !
They
-> > tell
-> > -> >>me
-> > -> >>in the man, that the fus 27 top flange should be bent to a 45 of
-> > web
-> > -> >>do they mean the table ? I don't seem to be getting this section.
-> > -> >>Thank you Dave T / rebel 009
-> > List archives located at: https://www.dcsol.com/login
jimsrebel
Here is a photo of the wing root with round hole cut in FUS 27
http://n254mr.com/gallery2/v/254R/Build ... S.JPG.html
-> Thanks,
-> Allen Poulsen
-> > then
flange
-> > -> Ken
be
-> > more
-> > saying does
They
-> > tell
-> > -> >>me
-> > web
rognal
Post by rognal » Sun Feb 19, 2012 11:04 am
Allen,
I didn't because I wasn't absolutely sure I could cut it so that the torque
tube would pass through it's center. I didn't want the FUS-27 hole to be
off center from the torque tube. I waited until I could mount the wing,
then used a short section of 1/4" rod slipped in the end of the torque
tube, extended out against the FUS-27 to mark the center for the hole. Then
use whatever tools it takes to 'hog' out the hole and smooth the edges.
It's more work than using a fly cutter, but not that much more. And it's
centered to the torque tube.
This photo shows the hole in the FUS-27 being cut using a nibbler -
http://tincantimes.dcsol.com/Default3_f ... 2650AA.jpg
I have since installed a doubler around the opening even though the manual
doesn't call out for one.
Hope this helps,
Roger Hoffman #687R
Eugene, OR USA!
apoulsen
Roger,
Thanks for the input. And thanks for posting all your pictures.
Go Ducks!
Allen
Sent: Saturday, August 19, 2006 2:17 PM
Allen,
torque
Then
Hope this helps,
Roger Hoffman #687R
Eugene, OR USA!
