hi all
i have scott oil temp and pressure gages
can someone tell me when temp probes goes into engine do you use teflon tape
or anything on threads ?
also with the murphy firewall forward kit there seems to be a ton of small
brass fittings for oil pressure line, has anyone used all these fittings,
what are they all for ?? also where do you get pressure tap from on the
engine ?? pics of test run of my engine from leavens shows line coming off
front of engine ??
mike#007
