Amphibious Floats
Posted: Fri Feb 17, 2012 5:40 pm
Your following message has been delivered to the 153 members of
the list murphy-rebel@dcsol.com at 19:49:43 on 18 Feb 2000.
Curt, that is the problem with jokes, you have to be very sure that you know
the people quite personally, so as not to insult ones Blonde wife, etc. I'm
sure Bob would add you to his mail list, if you sign a "no insult taken"
disclaimer!!!!!
PUMP OUT CUPS. Don't know if you noticed on my site, but the float
construction pictures show a good shot of the cups and hoses in two of the
forward sections. I used some good reinforced garden hose, so it doesn't
collapse from the vacuum. Works great full size, but of course leaves some
water behind that gets left in the hose (very minimal though). You should
only be pumping condensation out (that is the idea any way!), and the
greatest advantage of the cups, is the speed at which you can do a
preflight. The sound of the suction indicates no water, water or the hose
has fallen off. ALL have their own unique sound. You did buy the pump that
fits the cups from Lake and Air also?? Has rubber end to fit in cups,
available in long and short models. Save your back and buy the long one!!!!
As for the 2, -3 holes, I'm drawing a blank sitting at the computer. I have
to go out in the hanger shortly to take the battery charger off the 4
wheeler, so I will have a look at Howard's plane while I'm out there and
then drop you another line to the list!
Keep at it, Spring coming!!!!!!
Blue skies, Wayne
Date: Friday, February 18, 2000 7:24 PM
Subject: Re: Epoxy Chromate Primers
disclaimer!!!!!
Blue skies, Wayne
findHi Wayne, I've got a couple of questions on the amphib floats if you can
ifthe time. I guess Bobs jokes were just to good to share with us all.
Anyway, I'm using the Lake and Air pump outs and I was curious
inneryou had downsized the the tubing. I seems that 5/8 id all the way is pretty
large and I might not get a good pull with the syphon. Make sense? The next
question is a little more complicated in the decription. MAM has you drill
and tap 2 #10 holes in the lower front of the nose gear retract brackets.
Well, in laying out the proper angles for square to the surface in two
directions it seemed that this would put the holes really close to the
*----------------------------------------------------*opening for the guides, possibly taking some strength from a critical area.
In trying to keep the two screws and moving them around, 2 just seemed 2
many., I think I"ll just use one, any comments?
I appreciate the help, N97MR, Curt
