[rebel-builders] rear fus inside corner wraps?
Posted: Sun Feb 19, 2012 2:03 pm
Ben
The inside bulkhead flanges are certainly not overly large on the
corners but I riveted through them and both corner wraps at the joints.
I think there may have been at least one place that I joined two corner
wraps immediately ahead of, or behind, a bulkhead but I still rivetted
the wrap to every bulkhead and joined all the corner wraps front to
rear. One would think that it shouldn't matter very much what you do if
these are the rear inside floor and corner wraps that are optional?
Ken L.
bransom@dcsol.com wrote:
Ken L.
On the rear fuselage section it is unclear to me whether each corner wrap
should be riveted to the previous one where they overlap. There isn't enf
material on the inside bulkhead corners to rivet to, but still, the wraps
could be riveted to each other and make things a little stiffer.
Opinions/Suggestions?
-Ben
