Anyone wanna buy an almost finished Super Rebel?
Posted: Sun Feb 19, 2012 2:00 pm
I can't believe I have another major problem! I hooked up the left aileron
with the wing to fuselage push-pull rod and when moving the stick I noticed
the aileron bouncing a bit when I stopped moving the stick. I tied the
stick down and with it held in place I can move the aileron a full inch at
the trailing edge! I tried to narrow down where the worst of it is being
caused which I really need a second person to help do. Aileron to the wing
root end of the torque rod seems solid as a rock. The worst of it seems to
be the push-pull rod I just hooked up but again it's hard to be sure without
a second person to hold things. The frustrating thing is I reviewed the
entire system against the manual and I have built it exactly as described in
the manual. Every builder should have run into the same problem. There
should be a "to avoid excessive free play the builder should take care
to..." entry in the manual. HELLLLLPPPPP!
Went out to the hangar today and after weeks of no sign of leaks from the
tanks the left wing tank is leaking now!
What next?
044SR
What next?
044SR
