--------------14F2EB5BD474BF09F0CF8F15
Content-Type: multipart/alternative;
boundary="------------024509AAD58A3323CD5D829A"
--------------024509AAD58A3323CD5D829A
Hi Luke
Have an O 320 E2D mounted on my Rebel 190R with the firewall cut back 3
inches (picture attached). Mounted battery, strobe light power pack and
ELT one bulkhead behind the crank in the fuselage. My weight came out
at 1006 lbs with empty C of G at 12.1 inches. With full fuel and one
passenger it moved to 15 inches which is about dead center of the range.
Flies well and lots of control at low speeds. Up front have a
lightweight starter and genertor.
Hope this helps!
Glenn Cook
Rebel 190R
LUKE&BECKY wrote:
Hello to all builders; I'm new to the site and appreciate all the
helpful hints I've gleaned. I am just about to work on the control
systems and prior to "sealing my floor" I have a couple of questions
about wires that may need to be routed through the cabin. I would
appreciate any builder's comments on ideal battery location for an
O-320 weight engine install ( actually an EJ22, approx same installed
weight ). Likewise,any comments on ELT locations that have worked
well would be helpful.Thanks, Dave Luther
skydoc@nidlink.com
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
<body bgcolor="#FFFFFF">
Hi Luke
<p>Have an O 320 E2D mounted on my Rebel 190R with the firewall cut back
3 inches (picture attached). Mounted battery, strobe light power
pack and ELT one bulkhead behind the crank in the fuselage. My weight
came out at 1006 lbs with empty C of G at 12.1 inches. With full
fuel and one passenger it moved to 15 inches which is about dead center
of the range.
<p>Flies well and lots of control at low speeds. Up front have a
<p>Hope this helps!
<p>Glenn Cook
<br>Rebel 190R
<p>LUKE&BECKY wrote:
<blockquote TYPE=CITE> <font color="#000000"><font size=-1>Hello to
all builders; I'm new to the site and appreciate all the helpful hints
I've gleaned. I am just about to work on the control systems and
prior to "sealing my floor" I have a couple of questions about wires that
may need to be routed through the cabin. I would appreciate any builder's
comments on ideal battery location for an O-320 weight engine install (
actually an EJ22, approx same installed weight ). Likewise,any comments
on ELT locations that have worked well would be helpful.</font></font><font color="#000000"><font size=-1>Thanks,
Dave Luther <a href="mailto:
skydoc@nidlink.com">
skydoc@nidlink.com</a></font></font></blockquote>
</body>
</html>
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
mike.davis@dcsol.com
