fuel rate
Posted: Sun Feb 19, 2012 1:56 pm
4 EGTs, yes, but I don't quite get how the fuel monitor helps, i.e., you
can't just lean cuz it says it's thirsty. ??
-Ben
at every altitude. I usually cruise at 7.5 US gph where without this gauge
would likely be running at 8 or 8.5 if I just leaned to smooth running.
With my carb, all 4 EGTs don't peak at once, so a little playing around is
always necessary to get the best compromise.
-Ben
EGTs, RPM and ASI, to get the most fuel efficiency and smooth running RPMThis is where my fuel monitor really helps me. It allows me to lean with
Date: Monday, June 26, 2006 11:04 am
Subject: Re: [rebel-builders] 1800 amphibs
Oh. I just thought it was slower, but I guess if it means driving
aroundin high gear (flatter pitch), it is more power, more gas.
...and dangit,
more $, ...like most fun things
on theI don't know Ben....I could easily burn 9.5US gal/hr with FOKMdifferent engine, or'phibs.
Sent: Monday, June 26, 2006 1:24 PM
under thehad a bigrearthe threeredretracted.> AnyO-ringspositive on theminutes totransitioning on water.keeplove the plane.nose wheellitres/per/hour hours..............Angusleaked worsedremel toolthanfrom beingtothen installeddroppedtogether with onlthepressure holdsy athe cylinderforI'm stillbut------not--------5/9/2006--
