fuel rate
bransom
fuel rate
Post by bransom » Sun Feb 19, 2012 10:56 am
4 EGTs, yes, but I don't quite get how the fuel monitor helps, i.e., you
can't just lean cuz it says it's thirsty. ??
-Ben
This is where my fuel monitor really helps me. It allows me to lean with
EGTs, RPM and ASI, to get the most fuel efficiency and smooth running RPM
at every altitude. I usually cruise at 7.5 US gph where without this gauge
would likely be running at 8 or 8.5 if I just leaned to smooth running.
With my carb, all 4 EGTs don't peak at once, so a little playing around is
always necessary to get the best compromise.
Date: Monday, June 26, 2006 11:04 am
Subject: Re: [rebel-builders] 1800 amphibs
Oh. I just thought it was slower, but I guess if it means driving
aroundin high gear (flatter pitch), it is more power, more gas.
...and dangit,
more $, ...like most fun things
I don't know Ben....I could easily burn 9.5US gal/hr with FOKM
on the
'phibs.
Sent: Monday, June 26, 2006 1:24 PM
different engine, or
under the
rear
had a big
red
the three
O-rings
retracted.> Any
positive on the
minutes to
keep
transitioning on water.
love the plane.
litres/per/hour hours..............Angus
nose wheel
leaked worse
than
dremel tool
from being
dropped
then installed
together with onl
y a
pressure holds
for
the cylinder
but
I'm still
not
5/9/2006
