[rebel-builders] RE: wishbone bolts
Posted: Sun Feb 19, 2012 1:56 pm
by Ken
Isn't FUS-5 the 2" square tube? My manual says you can cut that in half
lengthwise and discard the front wall if using the bungee gear! ;)
I remember cautions not to put holes through the 1x2 vertical cage sides
though.
rognal@dcsol.com wrote:
Hi Jesse,
You mention making holes in the front carrythrough. Just want to make you
aware that in my builder's manual it specifically states " Do not drill any
holes in the front FUS-5". In my manual this is section 12.9 paragraph 16.
My understanding from this (and conversation w/MAM Tech) is that you
shouldn't make any holes in the front wall of the forward FUS-5 tube. I
don't know why.
Just FYI.
by Drew Dalgleish
I don't even have the front of FUS 5 I cut mine in half to save weight. Ya
gotta bolt the wishbones on somehow
At 09:33 AM 6/25/2006 -0800, you wrote:
Hi Jesse,
don't know why.
Just FYI.
On 6/24/2006 6:25 PM, jessejenks@hotmail.com wrote to rebel-builders:
-> I am working on the cage assembly. I was thinking of installing 5/16
anchor
-> nuts in the aft carrythrough to alleviate the need for inspection holes
-> be able to remove the wishbone for float installation. You would just
remove
-> the bolts through holes in the front carrythrough.
-> Has anyone tried this, or can anyone think of why it might not be a good
-> idea?
-> Thanks
-> Jesse
by apoulsen
Hello all,
I was hoping someone would address this. My manual says to rip FUS 5 in half
lengthwise (12.9.1) but then each of the next four references say either
full tube or half without explaining why. I seems that any weight saving
would be minor compared the reduction in strength.
What have you guys done and why?
Allen Poulsen
786R
Sent: Sunday, June 25, 2006 4:45 PM
Subject: Re: [rebel-builders] RE: wishbone bolts
though.
Hi Jesse,
any
don't know why.
Just FYI.
by Drew Dalgleish
At 07:44 PM 6/25/2006 -0400, you wrote:
Hello all,
Allen Poulsen
786R
If you're thinking of using the spring gear don't cut it as you need the
full width for attaching the gear. I cut mine to save weight. I don't think
that the reduction in strenth is an issue because I think it's way stronger
than the attachment points.
by Bob Patterson
Hi Allen !
Hardly anybody now cuts the tubes in half. If you have the spring
gear, you can't anyway, as you need the full width for attachment !
(of course, hardly anybody up here gets the spring gear ;-) )
There may not be much reduction in strength, but why reduce any ??!!
The weight saving WAS significant IF you were going ultralight,
with a small engine ...
On Sunday 25 June 2006 11:44 pm, apoulsen wrote:
Hello all,
Allen Poulsen
786R
though.
Hi Jesse,
any
don't know why.
Just FYI.
by Jesse Jenks
Thanks to all who responded,
I think I will use nutplates now that Drew confirms the idea works well. I
am now considering cutting just the front face off the front carrythrough.
This would still give me the platform for control column mounting, but would
allow easy access to the wishbone bolts, and ease the corner cage bolts
install. The rear carrythrough would still be full dimension.
I also have some special reasons for wanting to do this that have to do with
my rudder/elevator cables non-standard routing under the floor. It would
also create a nice pocket to hide wires or fuel/hydraulic lines that may end
up running across the cabin.
Date: Mon, 26 Jun 2006 02:56:24 +0000
Hi Allen !
Hello all,
half
Allen Poulsen
786R
half
sides
though.
you
drill
16.
Before you simply cut them in half......give some thought to where the
control column bearing holders sit.... since they require the full width of
the original tubes. Then use a good bandsaw and while cutting the tubes in
half swing in and out where the holders need to go to leave a pad to
rivet/bolt them to. Otherwise you will have to reinforce the floor behind
the rear tube for the safe retention of the rear flange of the bearing
holders ....as the rear flange will no longer be on the rear 2" tube if you
move the holders back to sit on the cut down forward tube.
Sent: Monday, June 26, 2006 11:15 AM
would
with
end
Hi Allen !
Hello all,
in
half
either
saving
Allen Poulsen
786R
half
sides
make
you
drill
paragraph
16.
tube.
by Jones, Michael
good point wayne, my cross tubes where cut in half by original owner and as
a result i have 1/8 plate installed to carry load of control column bearing
holders
mike#007
Sent: Monday, June 26, 2006 12:42 PM
would
with
end
Hi Allen !
Hello all,
in
half
either
saving
Allen Poulsen
786R
half
sides
make
you
drill
paragraph
16.
tube.
by rognal
Yes it is. My manual says the same (cutting in half lengthwise), but when I
talked with MAM Tech (at the time, Brian) cutting it in half was not
recommended (as was the drilling of holes). Don't ask me why it was still
in the manual. Anyway, I just wanted to bring it to Jesse's attention since
he asked.
Roger
On 6/25/2006 12:45 PM, klehman@albedo.net wrote to rebel-builders:
-> Isn't FUS-5 the 2" square tube? My manual says you can cut that in half
-> lengthwise and discard the front wall if using the bungee gear! ;)
-> I remember cautions not to put holes through the 1x2 vertical cage sides
-> though.
-> Ken
-> rognal@dcsol.com wrote:
-> >Hi Jesse,
-> >You mention making holes in the front carrythrough. Just want to make you
-> >aware that in my builder's manual it specifically states " Do not drill any
-> >holes in the front FUS-5". In my manual this is section 12.9 paragraph 16.
-> >My understanding from this (and conversation w/MAM Tech) is that you
-> >shouldn't make any holes in the front wall of the forward FUS-5 tube. I
-> >don't know why.
-> >Just FYI.
You absolutely have to drill holes in both tubes and over size the holes on
the outboard faces for socket access to install the wishbone tubes. No way
to install bolts without holes. A couple #30 holes to hold the anchor nut
are a non issue and if you are at all worried make sure the holes are
parallel to the tube edges so they will be on the neutral point of the
tube..and not in the compression or tension areas above and below center
(although like I said not an issue)
Sent: Monday, June 26, 2006 2:14 PM
since
he asked.
Roger
sides
-> though.
-> Ken
-> >Hi Jesse,
you
drill any
16.
-> >don't know why.
-> >Just FYI.
by Jesse Jenks
I just cut the front vertical face off the tube, so it still has the full
width on the top and bottom minus the radiussed corner. If I had a good
bandsaw I would have done what you describe. That's what I thought of
originally too, but all I have is a Delta bench top which has too much blade
wander for a job like that. I should still be able to mount the bearing
supports easily, and now I can use nuts and bolts on the front flanges, and
bolts in tapped holes for the rear flanges, or while I'm at the nutplate
thing, put some 3/16 nutplates in for the rear flanges.
Date: Mon, 26 Jun 2006 12:41:44 -0400
carrythrough.
would
with
end
Hi Allen !
in
half
either
saving
half
sides
make
you drill
paragraph
16.
you
tube.
by rognal
Of course you have to drill holes in both tubes to install the bolts. All
I'm saying is, after discussions with MAM (Brian), at that time they were
not approving the drilling of holes in the FRONT FACE OF THE FORWARD FUS-5.
Drill through the rear FUS-5, enlarge the holes in the rear wall of the
rear FUS-5 for a socket, and drill through the rear wall only of the
forward FUS-5, bolt together.
That's what I was told. That's what the manual inferred. That's the way I
did it. It didn't make a lot of sense to me at the time (still doesn't)
because I will have to take the floor panels up and the corner wraps off if
I ever want to access the bolts, but Brian said it wasn't an issue, and
I've never built an airplane before so I followed the instructions.
Again, I only mentioned it because Jesse asked for comments.
R. Hoffman #687R
Eugene, OR USA!
On 6/26/2006 1:04 PM, oifa@irishfield.on.ca wrote to rebel-builders:
-> You absolutely have to drill holes in both tubes and over size the holes on
-> the outboard faces for socket access to install the wishbone tubes. No way
-> to install bolts without holes. A couple #30 holes to hold the anchor nut
-> are a non issue and if you are at all worried make sure the holes are
-> parallel to the tube edges so they will be on the neutral point of the
-> tube..and not in the compression or tension areas above and below center
-> (although like I said not an issue)
-> Wayne
-> From: <rognal@dcsol.com>
-> Sent: Monday, June 26, 2006 2:14 PM
-> Subject: Re: [rebel-builders] RE: wishbone bolts
-> > Yes it is. My manual says the same (cutting in half lengthwise), but when
-> I
-> > talked with MAM Tech (at the time, Brian) cutting it in half was not
-> > recommended (as was the drilling of holes). Don't ask me why it was still
-> > in the manual. Anyway, I just wanted to bring it to Jesse's attention
-> since
-> > he asked.
-> > Roger
-> > On 6/25/2006 12:45 PM, klehman@albedo.net wrote to rebel-builders:
-> > -> Isn't FUS-5 the 2" square tube? My manual says you can cut that in half
-> > -> lengthwise and discard the front wall if using the bungee gear! ;)
-> > -> I remember cautions not to put holes through the 1x2 vertical cage
-> sides
-> > -> though.
-> > -> Ken
-> > -> rognal@dcsol.com wrote:
-> > -> >Hi Jesse,
-> > -> >You mention making holes in the front carrythrough. Just want to make
-> you
-> > -> >aware that in my builder's manual it specifically states " Do not
-> drill any
-> > -> >holes in the front FUS-5". In my manual this is section 12.9 paragraph
-> 16.
-> > -> >My understanding from this (and conversation w/MAM Tech) is that you
-> > -> >shouldn't make any holes in the front wall of the forward FUS-5 tube.
-> I
-> > -> >don't know why.
-> > -> >Just FYI.
by Jesse Jenks
Thanks for the info Roger. Is yours flying yet?
I know I say it every time you are on here, but thanks for the great
collection of construction pics on your website. Whenever I am getting ready
to tackle a new area it is an essential part of my studdies.
Date: Mon, 26 Jun 2006 16:28:45 -0800
R. Hoffman #687R
Eugene, OR USA!
on
way
nut
-> Wayne
when
-> I
still
-> since
-> > he asked.
-> > Roger
half
-> sides
-> > -> though.
-> > -> Ken
-> > -> >Hi Jesse,
make
-> you
-> drill any
paragraph
-> 16.
you
tube.
-> I
-> > -> >Just FYI.
