I upped the lower corner wraps (to firewall) and the piece under the
door (to the cage) to .025 but some people recommend .032 for those parts.
Is FUS-26 the triangle piece - I left that at .020 I believe some
people put a crease in that to match the crease that is in the door skins.
David L. Tuck wrote:
Can anyone tell me what thickness I should make these sections ? Seems to me
that I saw here they should be one size increase?
It looks like my fus 25 is .020 and the fus 26 is .025, and the fus 70 is
.030.
Does this sound correct ?
Should they be at the following size ?
fus 25. at .025 ?
the fus 26, at .030 ? and the fus 70, at .032 ?
Also when I went to start the forward fus, it seems like I have an incorrect
part ? as in the fus 39. mine is the exact size as the bottom skin and also
has the edges turned up like the side and bottom skins ? they tell me at mam
that this is the wrong part, and they are sending me a new one, can anyone
tell me what part I have ? as fus 39.
Thank you for all the help.
Dave tuck/ rebel 009
