[rebel-builders] how to stop real quick
Posted: Sun Feb 19, 2012 1:53 pm
An intentional ground loop can work. But you better be good. And you have
to make that decision split second. If you are facing a fence and bad stuff
beyond you can decide to try the ground loop if you want. The speed which
you enter the ground loop will determine whether there will be damage or
not. I've got one ground loop under my belt, unintentional. I made a bunch
of bad decisions and the ground loop did a lot of damage to the plane. I
think it's 6 of one, half a dozen another. I think Ted did just great doing
what he did. Straight ahead and do the best you can. That's so much better
than the turn back to the runway at low level to try and save the plane that
kills people. Ted chose people over metal. Perfect.
044SR
bransom@dcsol.com
Sent: Tuesday, June 13, 2006 9:44 PM
Subject: [rebel-builders] how to stop real quick
I've wondered about the idea of intentionally ground looping if in a
situation
such as Ted's or other where you are running out of room. I'm sure the
instinct is to jump on both pedals, but what about just one and let the dirt
fly? Any reason to keep this out of one's taildragger bag of 'oh *&^#$'
tricks?
-Ben
044SR
bransom@dcsol.com
situation
tricks?
-Ben
