SR IO-540 baffles
Tim Saxton
SR IO-540 baffles
Post by Tim Saxton » Sun Feb 19, 2012 10:52 am
I finally got the engine mounted and am ready to start on the baffles. I have paper templates for the baffles that came with the engine but it turns out the pattern is for an O-540. The cut outs for the cylinder heads are different; I suppose this is the difference between parrallel valve and angle valve engines. Mine is an angle valve (IO-540-G1D5). Where can I find templates for this engine? Better yet, does anyone have notes and pictures for a similar install? I could modify the O-540 templates to fit but I'm worried that there might be other dimensional differences that will make this more work than it seems.
Tim
SR060
