Sent: Wednesday, May 24, 2006 12:37 AM
Subject: RE: [rebel-builders] SR NACA duct location - experience from those
flying?
Yes they have a flow control valve. It's a simple butterfly that you
operate with your finger poked into the outlet hole and it seems to work
fine.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Clay
Smith
Sent: Tuesday, May 23, 2006 5:09 PM
Subject: Re: [rebel-builders] SR NACA duct location - experience from
those
flying?
Mike, It looks like those $18 plastic eyeball vents from ACS can control
direction of air flow, but can they also control the amount of air flow
like
the larger aluminum ones. I'm considering using these with a 1" scat hose
attached to a hole in the leading edge wing to fuse fairing. Something
like
Cessna. Anyone try this?
Clay
Sent: Tuesday, May 23, 2006 5:45 PM
those
flying?
The plastic eyeball vents that I have for fresh air are from Aircraft
Spruce
and only cost $18 each. The same thing in aluminum from ACS are $163
each.
I also have some plastic eyeball vents that I got from Vans originally
for
fresh air, but they were too big. From sheer luck those vents actually
worked perfectly on my heater box. They are about twice the size of the
ones from ACS.
044SR
Sent: Tuesday, May 23, 2006 10:45 AM
those
flying?
I'm pretty sure the ones Mike K has in his SR came from Vans... they're
plastic, not metal like the $$$ ones, but look like they'll work fine.
Mike D
Sent: Tuesday, May 23, 2006 6:01 AM
those
flying?
Speaking of NACA ducts and eyeball vents, does anyone know where one can
purchase eyeball vents that don't cost an arm and a leg?
Tom Packard
SR 043
--- http://USFamily.Net/dialup.html - $8.25/mo! --
http://www.usfamily.net/dsl.html - $19.99/mo! ---
__________ NOD32 1.1553 (20060522) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
