[rebel-builders] Seats and seat cushions - Again
Posted: Sun Feb 19, 2012 10:47 am
Gary Gustafson wrote:
around the tube and riveting on the side of the tube. the side is not
stressed during for and aft seat flexing. I copied someone else's idea
and am very pleased with Obus forme seat backs instead of foam in the
seatback.
seatbacks and both of those have definately had failures. Early ones
were supposed to be modded with some triangular bracing. Low backs are
rectangular with a horizontal top whereas highbacks are an inverted V at
the top.
live up North or down South as to the densities. In Ontario I used 1" of
one density and 2" of the other rather than 3 densities that is often
recommended in hotter regions. I used pink and blue but no green. Oh and
I added some wedges for thigh support and to keep from sliding out
sideways. Once you sit in a confor foam seat for a day - nothing else
will do!
tubes as I could.
available. Sheepskin is the very best IMO.
If you rivet (not everyone does) I recommend wrapping the materialI have read the Rebel Archives about seats and seat cushions, but do
not seem to find any consensus of opinion and in the process have
become concerned about my seats. What I found out was:
1. MAM's seat backs break and the rivet hole. There is a suggestion
to put the Aluminum on backwards to prevent breaking from occurring
and then I read that Wayne's seat broke while at tied down. Do
past builders now agree that the Aluminum should be put on
backwards? Mine are not!
seatback.
I believe both have had failures. There are two versions of the lowback2. The second thing I found out is that there have been two sizes of
seat frames - low and high backs. My plane is #242 and I suspect
that I have low backs. Are the failures from high back or low
back MAM frames?
the top.
Confor is mostly beneficial on the seat. It also depends on whether you3. There is a lot of discussion in about using ConforFoam (3 densities/
3 inches) in the bottom, 2 densities/2 inches in the back. What is the
Foam backing on the MAM leather seats? Does MAM use ConforFoam? I need a
lot of padding and like the idea of different densities to support the
load (no I am not fat, just big).
will do!
I added triangular bracing from the bottom to as high up on the side4. Are the MAM seats about equivalent to the Oregon Aero seats? What is
the thickness of the bottom seats - 3 inches? Are they made up of
varying densities?
5. What sort of bracing (or possibly frame size) have people settled on
for the seat backs to prevent breaking?
tubes as I could.
I don't like leather but I think MAM also has cloth upholstery kits6. It seams that for the cost that the MAM leather seats are reasonable
If there is enough padding? Any comments.
This is a lot of questions but if one reads the old archives, there seems to
be good cause for concern. I do not want my seat flopping back during
flight. Appreciate any and all comments.
Gary Gustafson
Rebel #242
