[rebel-builders] Vans parts
Post by Wayne G. O'Shea » Sun Feb 19, 2012 1:44 pm
I put an airwolf on Howard's 10 years ago. Works well. To use the B&C 45*
unit I think you need an 1 3/4 spacer for it to work. That number is from
memory...there are guys here that have installed it that can give the number
for sure.
Baffle kit will work...but of course you'll have to do some trimming to make
it fit the Elite cowl. As for the exhaust..doubtful !
Sent: Saturday, May 06, 2006 8:43 PM
Subject: [rebel-builders] Vans parts
Elite builders,
Does the Vans exhaust system and baffle kit work on the 0360 in the Elite?
How about the 45 degree spin on oil filter adapter, that puts the filter
pointing upper left, I'm thinking it will hit the engine mount? Any body use
anything other than a remote setup? Air Wolf?
Mike Betti
Alan Hepburn
Post by Alan Hepburn » Sun Feb 19, 2012 1:44 pm
Mike:
I am using the Vans baffles, carb air box, spinner, carburettor controls
bracket. All are satisfactory. Also the Air Wolf filter works well.
Al
Mike Betti
Post by Mike Betti » Sun Feb 19, 2012 1:44 pm
Thanks Wayne,
I would be interested in that part no. if any one has it. It would be nice
to have 2 less hoses hanging out there.
Mike Betti
771E
Sent: Saturday, May 06, 2006 7:48 PM
Subject: Re: [rebel-builders] Vans parts
number
for sure.
make
Elite builders,
Elite?
use
Mike Betti
Mike Betti
Thanks Al,
Who's exhaust do you have?
Sent: Saturday, May 06, 2006 9:26 PM
Subject: RE: [rebel-builders] Vans parts
Mike:
Al
Alan Hepburn
I have the standard Murphy one (Forsling). Jack Wiebe has a really
nice one, incorporating heater muffs. Not sure the manufacturere, but
could find out. The Murphy heater muffs are difficult to keep inside
the cowl.
Al.
mbetti
Post by mbetti » Sun Feb 19, 2012 1:44 pm
Al,
I don't know Jack Wiebe but I seen the name before, would appreciate if you could find out.
Mike Betti
771E
the cowl.
Al.
