[rebel-builders] Moose: Newly installed -- straight -- sting
Post by Wayne G. O'Shea » Sun Feb 19, 2012 10:44 am
Did you take the foam out of your tailwheel so the air can do it's job??
Sent: Friday, May 05, 2006 9:09 PM
Subject: [rebel-builders] Moose: Newly installed -- straight -- stinger
I installed a new prototype -- totally straight -- stinger on the Moose
today. I also put on a new swivel that a machinist friend of mine created
out of a blank-stock swivel that Murphy Aircraft sent. I uploaded a
of the install in the "115 S/M Landing Gear" area. The picture shows that
now have a slight positive castor angle when relatively empty. With the
plane loaded up I suspect I'll have the proper vertical pivot pin
orientation.
You can also see two pictures (very bottom of the page) and more info on
tail upgrades at: http://www.i1ci.com/flying/Moose/Tail/TailUpgrade.html
Ted Waltman
