All metal ailerons - Rebel??
T L McClary
Post by T L McClary » Fri Feb 17, 2012 8:39 pm
As I start work on my ailerons I can't help but wonder, Why an aluminum
and fabric combination instead of all aluminum? Just thinking about it
from a maintenance standpoint, with all aluminum I never have to worry
about a fabric replacement and painting.
Any one tried all aluminum ailerons or have any comments?
Terry
________________________________________________________________
YOU'RE PAYING TOO MUCH FOR THE INTERNET!
Juno now offers FREE Internet Access!
Try it today - there's no risk! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
Post by Wayne G. O'Shea » Fri Feb 17, 2012 8:39 pm
Your following message has been delivered to the 146 members of
the list murphy-rebel@dcsol.com at 21:10:54 on 25 Jan 2000.
Terry, to save me typing it all over again I have forwarded info I just
recently sent to another builder! Aluminum flaperons/ailerons must be
balance 100%plus, to avoid the potential for flutter. It is felt that fabric
surfaces are much less prone to flutter and therefore the reason Murphy
designed this way. I covered mine in aluminum in 1994! Have done all
aircraft since with fabric.
To: Mike Jones <Mike.Jones@agra.com>
Date: Tuesday, January 18, 2000 3:58 PM
Subject: Re: rebel aileron covering
Hello Mike,
I used .016" 6061-T6 to cover my flaperons. One full sheet(4X12) sheared
into eight - 1' X 6' pieces allows them to be overlapped and joined at the
center. Don't forget that they must be counter balanced to avoid possible
flutter problems. I didn't want fabric on my aluminum aircraft either and
was the first to go this route. Don't know of any others that have covered
in aluminum to this date! (do you) You do not want to cover until you have
the flaperons assembled to the wing and have the tips and root gap filler
in
place. This is so you can do the overlap at the center hinge and fill the
gaps between the flaperon and the tip and the flaperon and the root gap
filler. No sense loosing any lift!
Now that I have been flying the other Rebel with fabric flaperons, I do
prefer the stick feel with it however (lighter forces). This is probably
only because of the counter weights on mine hanging down into the wind and
effecting the stick forces.(I haven't gotten brave(or stupid) enough to
remove them for a comparison flight) If you can come up with a better way
counterbalance (lead in the leading edge of the flaperon maybe) so as not
effect the stick forces, I would think the stick forces would be the same
as
fabric flaperons. Also keep in mind that I had to use approx. 8 pounds on
each flaperon to balance 100%+, and the weight is a fair distance ahead of
the pivot point. So I have added 16 pounds, plus the small increase of
using
the aluminum instead of fabric. Also, if you were to put the lead in the
leading edge of the flaperon, it would take considerably more weight to
balance them. Fabric starting to sound good now???? Something to give some
serious thought too, and does not have to be done until the very last
minute
after you have assembled you aircraft.
Time wise, it takes almost the identical length of time to do the fabric as
it does to drill, debur, chromate and rivet the aluminum.
Hope this helps,
To: oifa@irishfield.on.ca <oifa@irishfield.on.ca>
Date: Tuesday, January 18, 2000 1:46 PM
Subject: rebel aileron covering
Hi Wayne
What tickness of aluminum did you use on your ailerons, i dont want
fabric,
mike
Post by Bob Patterson » Fri Feb 17, 2012 8:39 pm
The reason they're fabric covered is the same reason Mustangs, Spitfires,
and DC-3s had fabric covered control surfaces - you avoid FLUTTER !!
Having your ailerons come off in flight is NO FUN !! ;-)
Seriously, you could cover them in metal, but you must add about 16 lb.
of mass balance forward, which can be ugly, add drag, and be a hazard to
your head on walkarounds ! It has been done - right Wayne ?? :-)
If you apply a good layer of silver dope, you will keep the sun off
the fabric, and it will last forever ....
As you so often see on this list "just build it by the book - you'll
just LOVE the finished Rebel !!"
------------------------------orig.-----------------------------------------
Terry
Post by Wayne G. O'Shea » Fri Feb 17, 2012 8:40 pm
Your following message has been delivered to the 145 members of
the list murphy-rebel@dcsol.com at 08:18:48 on 26 Jan 2000.
That is right Bob,
I have knocked my self out at least twice on the counterweights and awoken
on the hanger floor!!!
(But the aluminum is much nicer in appearance)
Date: Tuesday, January 25, 2000 11:43 PM
Subject: Re: All metal ailerons - Rebel??
Spitfires,
Terry
Doug Martin
Post by Doug Martin » Fri Feb 17, 2012 8:40 pm
Check with MAM the Elite's are all metal?
Doug in Reno
Terry
Doug Martin
greyghost@powernet.net
T L McClary
Post by T L McClary » Fri Feb 17, 2012 8:40 pm
Thanks for the input Wayne and Bob.
Bob, I appreciate your "build it by the book" commentary but I have to
run my ideas out for discussion when they come up. Hate to pass up an
opportunity because I didn't question an idea. (And, I didn't take your
comment personal. Just wanted to let you know where I was coming from.)
Terry
you'llbuild it to the book" On Tue, 25 Jan 2000 23:23:35 -0500 Bob
Patterson <bob.patterson@canrem.com> writes:
Spitfires,
16 lb.
hazard to
off
you'll
aluminum
about it
worry
Terry
Post by Bob Patterson » Fri Feb 17, 2012 8:40 pm
I agree completely !! That's what this forum is for - we throw out
ideas & all learn something. It's not the first time this suggestion has
come up, and I'm sure it will continue to surface - shows people are
looking for ways to improve the Rebel !!
Terry
Spitfires,
16 lb.
hazard to
off
you'll
aluminum
about it
worry
Terry
the list murphy-rebel@dcsol.com at 20:26:54 on 26 Jan 2000.
Doug,
They are also both statically and aerodynamically(spades) balanced!
Blue skies,
Date: Wednesday, January 26, 2000 8:12 PM
Doug in Reno
Spitfires,
lb.
Terry
Doug Martin
Wayne's right !! The Elite ailerons & flaps are COMPLETELY different
animals - there are extra hinge supports, weights in the front, and
large aerodynamic balance horns at the outboard ends.
Again - they added a lot of weight, complexity for building, and
lost roll effectiveness. Why ?? Because a bunch of potential customers
thought aluminum would look more like a "real airplane" - the old
"Cessna did it, so it must be good" thing !!! ;-(
(same reason the Elite was originally a tricycle ...)
-------------------------------orig.--------------------------------------
At 08:22 PM 1/26/00 -0500, you wrote:
Doug,
Blue skies,
Doug in Reno
Spitfires,
lb.
At 08:17 PM 1/25/00 EST, you wrote: *----------------------------------------------------*
Doug Martin
Gaetan Tremblay
Post by Gaetan Tremblay » Fri Feb 17, 2012 8:40 pm
That's mean that we should throw away the metal skins and couterweights then
install fabric on those elevators and flap. We will get best of both world?
Gaetan Tremblay
E660
-----Message d'origine-----
De : Bob Patterson [mailto:bob.patterson@canrem.com]
Envoy
I think the idea with the tail was that a little extra weight back
there was a 'Good Thing'(tm) :-)
Also, the balance weights and horns REALLY helped the control feel
and response on the rudder and elevator.
I know - the original Rebel had fabric covered rudder & elevators,
and NO balance horns, and I flew it like that !
--------------------------------orig.---------------------------------------
At 12:50 AM 1/28/00 -0500, you wrote:
[quote]That's mean that we should throw away the metal skins and couterweights then
Gaetan Tremblay
E660
Envoy
