Received: from MMoreho699@aol.com
by imo26.mx.aol.com (IMOv13.ems) id GIYKa02202;
Wed, 8 Apr 1998 13:03:22 -0500 (EDT)
Message-ID: <7dd5b1e.352baddc@aol.com>
Date: Wed, 8 Apr 1998 13:03:22 EDT
To: murphy-rebel@dcsol.com, murtech@murphyair.com
Mime-Version: 1.0
Subject: Tank drain holes, aileron hinge insp. holes, control horn center
hole
X-Mailer: AOL 3.0 for Mac sub 84
Hello!
How do you feel about water drain port for the tanks? I haven't put them in
yet and recall one person saying they had a water trap at the lowest point
the fuel system. This was in the line somewhere, not in the tank itself.
I also installed an aileron hinge inspection hole on the bottom as opposed
Murphy's recommendation of having topside access. I did this only for the
middle hinge and could move to the top for the other. Ideas?
And the control horns have center holes through which a bolt is TEMPORARILY
placed, not permanently, right? And what is the #11 hole drilled 1.5" from
distal hole of the root end control horn for?
Remember: Lowering expectations is a key to peace of mind!
Dan
R280
