New builder again w/? about worktables.
Posted: Fri Feb 17, 2012 8:39 pm
All,
I wanted to thank all of you who offered advice for my questions on air
compressors, drills, deburring, rivet pullers, etc. A lot of you responded
with your ideas and opinions. This is great! You have helped me a lot.
By the way Harbour Freight had the pneumatic rivet puller reduced from $49
to $25.
My next question is about the worktable. I believe I read somewhere that
Murphy has plans for one in their builder's manual. Should I wait for
Murphy's plans or start building the table?
I've also read suggestions that say you should build the table in sections
which you can bolt together for a larger surface as needed. Such as two
tables 4' x 8' which when bolted together could become 4' x 16', etc;...AND
perfectly flat, square, and true.
This 'modular' table idea appeals to me as I'm somewhat limited for space.
So I thought I'd ask for your suggestions.
Also, if 'modular' is acceptable, what size worktable top would you
recommend I need to start construction of the tail kit?
Roger
Eugene, OR USA
to $25.
Roger
Eugene, OR USA
