[rebel-builders] Weight & Balance
Posted: Sun Feb 19, 2012 1:43 pm
Interesting weight and balance with the FLs. How did you get your c of g so
far back? Are the FLs aft heavy? What was your empty weight on wheels? What
is your float angle relative to the bottom of the cabin or top window sill?
Thanks for sharing.
My ready to fly empty weight on my 1800 amphibs with the 0320 is 1250
pounds. That includes a full survival kit, paddle, etc.
Also, where are you located, Alvin?
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Alvin
and Glenys Adams
Sent: Thursday, April 27, 2006 5:00 PM
To: rebel
Subject: [rebel-builders] Weight & Balance
Gooday To all;Just finished my weight & balance on rebel with 160hp,prince
prop On 2150 full lotus floats.Split flaps,Mckenzie kit.
For anyone interested here are results.
Empty weight with oil 1240LBs CG- 14.38
Which Means: Pilot 190lbs
Pass 190Lbs
Fuel 110
Empty weight 1240
Total 1730Lbs Which is grose weight.
Legally with two people i can take only 15 gallons fuel no luggage.
What is average weight off reb el on Murphys Amphibs.
Of course i will get 2000lb groos aproved later.
Does above information sound correct or am i missing something.
Regards Alvin R776
Thanks for sharing.
and Glenys Adams
To: rebel
Pass 190Lbs
Fuel 110
Empty weight 1240
Regards Alvin R776
