will never be agreed upon. I prefer it to "trail" ..IE..nose of the pivot
lower than the back just like you have. Nose up makes for twitchy ground
handling... as as soon as it starts to turn it wants to pass itself ass over
tea kettle.
Sent: Saturday, April 22, 2006 11:20 PM
Subject: [rebel-builders] Moose: Tail update...new wrinkle in FUS-422
webpage.I installed the new stinger and related bulkhead improvements last fall in
my Moose as noted here:
http://www.i1ci.com/flying/Moose/Tail/TailUpgrade.html
I now have a wrinkle on either side of the tail wrap, FUS-422, caused, I
believe, by me trying to turn the plane and the tailwheel not immediately
unlocking and swiveling. I posted three pictures of these wrinkles in S/M
107 Fuselage. You can also see the pictures here
http://www.i1ci.com/flying/Moose/Tail/T ... tml#fus422 on my
myThere was a lot of discussion at that time about the castor angle on the
swivel, and whether having a positive or negative angle improved ground
handling. My swivel currently angles down toward the front, which, I
believe, is not appropriate. I had a discussion with Darryl Murphy about
this and he agreed that the swivel should angle up; just the opposite of
I'llcurrent tailwheel swivel angle. [As an aside, Darryl has sent me a new
prototype stinger that is totally straight. I will be installing and
testing this soon--within the next two weeks I hope.]
I hope that installing a new stinger and having a proper castor (angle) on
the swivel will improve ground handling and reduce stress on FUS-422.
FUS-422be keeping an eye on these wrinkles to insure they don't get worse.
rightis already pretty thick stock; I don't think having it thicker is the
swivelway to go. Nor do I think that adding a small reinforcing "hat" on each
side is appropriate. My sense is that we just have to get the right
angle and this problem won't happen with your moose.
Maybe I should just put it on floats and be done with these tail issues
<grin>.
Ted Waltman
