[rebel-builders] Rebel filler caps
Post by Wayne G. O'Shea » Sun Feb 19, 2012 10:39 am
Gary....if you change them to flush mounts what are you going to grab as you
are falling off the ladder???
;O)
Sent: Tuesday, April 18, 2006 9:08 PM
Subject: [rebel-builders] Rebel filler caps
Having purchased my Rebel (#242) from two previous builders, my wings had
already been
assembled with raised gas caps and the tanks are sealed. However, I note
that most
pictures of Rebels posted on the web site have flush mounted gas caps (as
far as I can tell
except the Sloan Rebel).
What are the pro and cons of going with a flush mounted gas cap (hopefully
vented) and
how much trouble is it to change existing raised gas caps? I like the
aesthetics and the
cleaner aerodynamics of the flush mounted caps. Any strong opinions on
this
before I
entertain any more ideas of changing the current raised gas caps.
Gary Gustafson
Post by Drew Dalgleish » Sun Feb 19, 2012 10:43 am
already been
that most
far as I can tell
vented) and
aesthetics and the
cleaner aerodynamics of the flush mounted caps. Any strong opinions on this
before I
Gary Gustafson
Most rebels have raised gas caps. vented flush caps tend to funnel rain
water into the tank. Once your rebel is completed only really tall people
will notice the aesthetics of the flush caps. Flush caps are probably more
aerodynamic but because of the boundry layer maybe not quite as much as you
hope. Raised caps give you something to grab onto when you slip while
fueling your plane.
Post by Bob Patterson » Sun Feb 19, 2012 10:43 am
Hi Gary !
I agree with all the comments - most Rebels have raised caps, and
this is likely the best way to leave them !!
Carry on - just GET IT FLYING !!! :-)
already been
that most
far as I can tell
vented) and
aesthetics and the
before I
Gary Gustafson
Gary Gustafson
Post by Gary Gustafson » Sun Feb 19, 2012 10:43 am
Good one Wayne. I bet you chuckle when you can set a good reply
G. O'Shea
Sent: Tuesday, April 18, 2006 9:28 PM
Subject: Re: [rebel-builders] Rebel filler caps
;O)
already been
that most
far as I can tell
vented) and
aesthetics and the
this
before I
Gary Gustafson
Gary Gustafson
You and Wayne think in the same circles. Must be from experience.
Dalgleish
Sent: Tuesday, April 18, 2006 9:48 PM
already been
that most
far as I can tell
vented) and
aesthetics and the
before I
Gary Gustafson
fueling your plane.
