The H2-AD was about the worst engine Lycoming has made lately - they
ALL had problems with the cams, although I hear there are "fixes". One
big problem is that they don't fit the standard Rebel engine mounts
OR the speed cowling .... according to Rob Rayford.
The consolation is that they ARE cheap ! ;-)
PS
I changed the SUBJECT line above ....
-------------------------------orig.------------------------------------
At 08:18 PM 1/19/00 EST, you wrote:
*----------------------------------------------------*Hi Bob,
Just thought I'd pass along a little engine tidbit. I just came acrossed
2 o-320H2ad engine cores. It was also stated they had a "T" designation which
is supposed to be a later model.(I"m not sure about that) They were both
running when remove from aircraft. They have logs but I don't know the
numbers. The A+I that owned them passed away and friends are helping clear
out his hanger. Probably can be bought for around 3000 US. They had all the
accessories still bolted on. Any greater intrest and I'll either put them in
touch with the family or get the info.
Keep at it, It's worth it Curt N97MR
