[rebel-builders] Moose Stinger eyeball
Posted: Sun Feb 19, 2012 10:35 am
by Bill Delcambre
Monty,
Why Stainless? True, it looks prettier, but who's gonna see it? If, for
some reason, you just feel the need, a suggestion; Assuming that the
original is machined from 4130, I'd be a bit careful about the alloy
choice. The 300 series alloys (308, 316, etc.) are not as hard as the
4130. Also, they don't respond to heat treatment for additional
strengthening as the original piece may be heat treated (just a guess). Not
as hard means not as strong and all that means more likely to fail. If you
must do it out of a corrosion resistant alloy, I might suggest 17-4PH. This
is a hardenable 'stainless' alloy that does respond to heat treatment and
will mimic the mechanical properties of the original part. Your machine
shop will have the material in the 'normalized' condition. After machining,
tell them you want it heat treated to 125ksi minimum.
Personally, I'd stick with the 4130, but that's me.
Bill
On 3/26/06, Warren & Marg Montgomery <monty@emirates.net.ae> wrote:
As I have to machine out the stinger eyeball I was thinking of having
redone in SS.
Any reason not to and is there a specific type of SS I need to use or
whatever the shop has in stock okay?
I can get it done rather cheap here as I understand.
Warren
Dubai, UAE
by Warren & Marg Montgomery
Thanks Bill,
A friend is blowing a 60 Buick to 1100 hp and has had many of the
fittings redone in SS for a very resonable cost.
Of course over here I doubt I'd find the true alloy. As my eyeball keeps
getting a coat of rust thought it might be the answer..
I guess I'll just slope with chromate before final install.
Warren
Bill Delcambre wrote:
Monty,
Bill
redone in SS.
Warren
Dubai, UAE
