Can anybody give me an idea of how many layers of 5.8oz S-Glass I'll need
for the nose cowl? I was thinking something like 1 layer at 45 degrees,
then another layer 90 degrees to the first layer, then another layer aligned
with the airplane's longitudinal axis as someone suggested. But it seems
like that wouldn't be very thick. I wonder if I should repeat the layers
until I have a total of 6 layers or if that is overkill. S-glass is 30%
stronger and 15% stiffer than hardware store E-glass and so fewer plies
should be required.
044SR
Fiberglass Layers
Fiberglass Layers
Resending in case it didn't make it to the list the first time. I'm about
to order the stuff to finish this thing off. Thanks.
Sent: Friday, March 24, 2006 1:37 PM
To: Rebel Builder's List
Subject: Fiberglass Layers
should be required.
044SR
should be required.
044SR
