Super rebel rudder
Super rebel rudder
Post by Mike Davis » Fri Feb 17, 2012 4:20 pm
Received: from sps1 (1Cust194.tnt4.sea1.da.uu.net [208.253.68.194])
by smtp2.mailsrvcs.net with ESMTP id TAA13718
for <murphy-rebel@dcsol.com>; Sat, 4 Apr 1998 19:08:31 -0600 (CST)
Message-Id: <199804050108.TAA13718@smtp2.mailsrvcs.net>
Reply-To: <paxhia@gte.net>
Subject: Super rebel rudder
Date: Sat, 4 Apr 1998 17:18:29 -0800
X-MSMail-Priority: Normal
X-Priority: 3
X-Mailer: Microsoft Internet Mail 4.70.1161
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
SR2500 Rudder
I have clecoed the rudder skin is in place but it does not fit very well.
It oil cans in the four large rib bays. Has anyone added additional ribs or
stringers to the rudder in the large bays?. If so how did you do it? What
material did you use? Are there any Issues?
Al Paxhia SR 026
Super rebel rudder
Post by Mike Davis » Fri Feb 17, 2012 4:21 pm
Received: from ts20-05.tor.istar.ca [204.191.150.148]
by mail1.toronto.istar.net with smtp (Exim 1.80 #5)
id 0yMjDl-00074w-00; Tue, 7 Apr 1998 21:00:09 -0400
Mime-Version: 1.0
Subject: Re: Super rebel rudder
Message-Id: <E0yMjDl-00074w-00@mail1.toronto.istar.net>
Date: Tue, 7 Apr 1998 21:00:09 -0400
There are several MAJOR issues here ! If you add extra stiffness,
and WEIGHT, to ANY control surface, you may mess up the BALANCE - both
static, AND dynamic. Control flutter can spoil your whole day !!
I've seen (& heard!!) control flutter on fibreglass gliders - it makes
your hair stand on end !! (and that's from the OUTSIDE, watching !!)
Please check with the factory before making changes - it's possible you got
a defective skin, or JUST MAYBE, once you have applied the epoxy chromate &
rivetted, the structure will become much stiffer....
------------------------------------orig.---------------------------------
At 05:18 PM 4/4/98 -0800, you wrote:
SR2500 Rudder
Al Paxhia SR 026
Super rebel rudder
Received: from sps1 (1Cust17.tnt6.sea1.da.uu.net [208.253.73.17])
by smtp2.mailsrvcs.net with ESMTP id WAA24359
for <murphy-rebel@dcsol.com>; Wed, 8 Apr 1998 22:01:23 -0500 (CDT)
Message-Id: <199804090301.WAA24359@smtp2.mailsrvcs.net>
Date: Wed, 8 Apr 1998 19:52:02 -0700
X-Priority: 3
MIME-Version: 1.0
Bob and Charlie, Thanks for the reply's. I talked to the factory, they
think the problem will go away when its riveted. That seems to fit with
what Charlie found. I confirmed that my problem is the bend radius on the
trailing edge of the rudder skin. For now I'll let it sit and keep working
on the wings. Al
