side of your baffles. Whether you need it or not depends on how hot it is
under your particular cowl. I've had good luck so far with my nipondenso
alternator that has no aditional cooling.
At 09:32 PM 3/13/2006 -0600, you wrote:
back for maybe hooking a hose to. The nipple end is broke off and I need toHi all,
My 0360 engine core has a Prestolite alternator with a black cover on the
repair. Is this cover necessary and if so, where does it connect to?
DrewThanks,
Mike Betti
771E
