[rebel-builders] REB: Position lights
Posted: Sun Feb 19, 2012 10:31 am
by Bob Patterson
Hi Jim !
Nowadays, I'd have to very seriously consider LED lights
from : www.GS-Air.com Nav & Strobe - low current, low $$ ! ;-)
https://ssl.perfora.net/gs-air.com/sess ... shopscript
On Sunday 12 March 2006 09:09 pm, pequeajim@dcsol.com wrote:
What have you guys done for position lights on the tail?
by Alan Hepburn
On the Elite I used the Aeroflash combined colour/white lights (plus
strobes) (ACS # 156-0039-12V), and didn't bother with a dedicated light on
the tail. The inspector didn't object.
As supplied, they need the grounding of the nav light improved - it just
relies on trapping the ground braid between the base and the cover, and mine
failed in the first month.
Al
by Rebflyer
Not sure what the Canadian regs say, but the way the US regs read, the tip
strobes with the white light give the proper lighting view. If going LED's
check with the person doing the certification. It was a problem in one area, but
the examiner was FAA direct instead of a DAR. If your past that point, the
EAA will give you names of a DAR in your area. The EAA supports the led
lights.
IMHO Curt N97MR
by Ron Shannon
Del, what kind of tubing (material, size, etc.) did you use?
254R
Del Schmucker wrote:
I put my tube in the leading edge and worked fine. I didn't have to secure
it to the ribs. When I did mine this way it was recommended by MAM.
by pequeajim
Bob:
It looks like this contains everything I need. Looking from the rear, another
pilot would see two solid white lights, and two flashing strobes?
Jim!
On 3/12/2006 6:36 PM, beep@sympatico.ca wrote to rebel-builders:
-> Hi Jim !
-> Nowadays, I'd have to very seriously consider LED lights
-> from : www.GS-Air.com Nav & Strobe - low current, low $$ ! ;-)
-> https://ssl.perfora.net/gs-
air.com/sess/utn;jsessionid=1543b2bd350d65c/shopdata/index.shopscript
-> ......bobp
-> -------------------------------orig.-------------------------
-> On Sunday 12 March 2006 09:09 pm, pequeajim@dcsol.com wrote:
-> > What have you guys done for position lights on the tail?
by pequeajim
What about the red beacon on the tail? Is this required in the USA if you
already have wingtip position lights?
On 3/13/2006 4:44 AM, rebflyer@aol.com wrote to rebel-builders:
-> Not sure what the Canadian regs say, but the way the US regs read, the
tip
-> strobes with the white light give the proper lighting view. If going LED's
-> check with the person doing the certification. It was a problem in one
area, but
-> the examiner was FAA direct instead of a DAR. If your past that point,
-> EAA will give you names of a DAR in your area. The EAA supports the led
-> lights.
-> IMHO Curt N97MR
by Rebflyer
Nope, the red beacon is not required. Position lights only. I do run tip
strobes too, but no beacon. Curt N97MR
by Bob Patterson
Yes ! The white lights on the back of the tips meet the requirements
for a white light visible from behind. No need for a separate white
light on the tail .... although you might need one on top as a "mooring
light" if you were going to anchor on floats at night ... That would
sure be hard on a battery, I would think ! :-)
On Tuesday 14 March 2006 05:20 pm, pequeajim@dcsol.com wrote:
Bob:
another pilot would see two solid white lights, and two flashing strobes?
Jim!
-> Hi Jim !
-> ......bobp
by pequeajim
Bob:
How did you run the wiring through the wing , in the leading edge?
Jim!
On 3/14/2006 5:46 PM, beep@sympatico.ca wrote to rebel-builders:
-> Yes ! The white lights on the back of the tips meet the requirements
-> for a white light visible from behind. No need for a separate white
-> light on the tail .... although you might need one on top as a "mooring
-> light" if you were going to anchor on floats at night ... That would
-> sure be hard on a battery, I would think ! :-)
-> .....bobp
-> On Tuesday 14 March 2006 05:20 pm, pequeajim@dcsol.com wrote:
-> > Bob:
-> > It looks like this contains everything I need. Looking from the rear,
-> > another pilot would see two solid white lights, and two flashing strobes?
-> > Jim!
-> > On 3/12/2006 6:36 PM, beep@sympatico.ca wrote to rebel-builders:
-> > -> Hi Jim !
-> > -> Nowadays, I'd have to very seriously consider LED lights
-> > -> from : www.GS-Air.com Nav & Strobe - low current, low $$ ! ;-)
-> > -> https://ssl.perfora.net/gs-
-> > air.com/sess/utn;jsessionid=1543b2bd350d65c/shopdata/index.shopscript
-> > -> ......bobp
-> > -> -------------------------------orig.-------------------------
-> > -> On Sunday 12 March 2006 09:09 pm, pequeajim@dcsol.com wrote:
-> > -> > What have you guys done for position lights on the tail?
by Bob Patterson
The preferred way is inside a plastic or metal tube near the spar.
For some reason, the factory did not recommend running wires inside
the leading edge D tube ....
On Tuesday 14 March 2006 10:19 pm, pequeajim@dcsol.com wrote:
Bob:
Jim!
requirements -> for a white light visible from behind. No need for a
separate white -> light on the tail .... although you might need one on
top as a "mooring -> light" if you were going to anchor on floats at
night ... That would -> sure be hard on a battery, I would think ! :-)
-> .....bobp
-> > Bob:
rear, -> > another pilot would see two solid white lights, and two
flashing strobes? -> >
-> > Jim!
-> > -> Hi Jim !
air.com/sess/utn;jsessionid=1543b2bd350d65c/shopdata/index.shopscript ->
-> > -> ......bobp
by Ron Shannon
Any ideas why the D tube might not be a good wire route?
by Del Schmucker
Thank You,
Del Schmucker
Information Systems Manager
Keewatin-Patricia District School Board
807-223-1254
807-221-8769 Cell
del.schmucker@kpdsb.on.ca
www.kpdsb.on.ca
Shannon
Sent: Tuesday, March 14, 2006 10:45 PM
Subject: Re: [rebel-builders] REB: Position lights
by Alan Hepburn
I ran mine inside a plastic tube in the D tube up to the strut, then down
the strut. Once the forward attach bolt is in place, it'd be pretty cramped
getting wires in a protective sleeve past the bolt head.
Al Hepburn
by Bob Patterson
OOooopps ! You're right Al ! I forgot to mention that the tube
only went tip to the strut, then wires down the strut !! This is
a LOT easier way to get the wires, and pitot tubing, to the back
of the panel ...
A good reason for not using the leading edge - you'd have to
go back through the spar to get to the strut !!
I think the objection to the leading edge was based on loose wires,
as opposed to wires inside an insulated tube. That way, they couldn't
vibrate, wear through the skin, or insulation, and short out ...
I believe there have been cases of loose wires wearing right through
skins !!
cramped getting wires in a protective sleeve past the bolt head.
Al Hepburn
by Alan Hepburn
Yep, and another thing, install a terminal block on the front of the spar
somewhere you can get at it near the front strut attach access cover. Do it
before you rivet the LE skins on - much easier (I didn't, so I know!).
Al
