[rebel-builders] SR - First flight
Posted: Sun Feb 19, 2012 1:31 pm
Congratulations Charlie!!!! Big day in any builders life...that's for sure.
Sent: Wednesday, March 08, 2006 8:23 PM
Subject: [rebel-builders] SR - First flight
O-540 A4-A5 with two blade Hartzell constant speed. One minor oil leak at
cooler fitting (easily repaired) and CHT's slightly above desired were
noted. Aileron response was somewhat less than anticipated, but elevator
and rudder were as desired. Electric rudder and elevator trim were
adequate, responsive and controllable throughout entire range. Electric
flaps operated throughout entire range as desired. Hands-off flight
throughout entire speed range with appropriate trim. Empty weight came out
slightly higher than anticipated, but extra equipment was added (electric
flaps, rudder trim, full IFR radios and instruments, corrosion primer on all
interior surfaces, extra fuel tank bays, etc.) Hope to deal with CHT by
experimenting with cowl air exit during next hours of testing. Almost eight
years of work, but very satisfied. Will
Mike figured out the problem (as usual) and corrected it -- so here goes:I've tried to send this some days ago, but was unsuccessful. Good old
Thurs. 3/2/06 (1:05 flight) with no major problems to report. Powered by an------------------------------
Happy to report that first flight of Super Rebel N96CS was completed
fly the 25 hr's of test time an
d
then paint.
Charlie Starr SR #065
