What do you folks use to cut holes for access (like the access hole near
the strut fittings)? I am on a budget and hate to buy a tool for every
step (actually I would love to buy a tool for every step, but my
marriage would not survive).
Kind Regards
Scott
hibbs@pacifier.com
Access hole cutting?
Wray Thompson
Scott I've used a cut-off wheel in my dremel at times and I have a small
nibbler I've used and of course there's always the old drill, drill, drill,
file file file and I suspect others have even different ways.
Scott wrote:
Wray Thompson ...Rebel 306 ...home page http://www.globalserve.net/~cobbg/
Scott wrote:
--What do you folks use to cut holes for access (like the access hole near
Kind Regards
Scott
hibbs@pacifier.com
LisaFly99
SCOTT
You can use a hole saw if you mark the spot and then do it on the bench or
use a drill press just back it up with a piece of wood and stabilize it good.
Do some practice holes in some scrap first. Or if you know an electrician
they have or can barrow different size hole punches used for putting holes in
electrical panels.
Phil&Lisa Smith #460
electrical panels.
Be careful if you use a punch to make holes ! You must remove a bit of
extra metal around the hole if it is punched, as the punching process
will stress the metal at the edge of the hole. If not removed, this
metal will 'star' crack over time, and you could have problems.
Generally, it is better to make an oval hole, rather than a round
hole, because it is then possible to make a one-piece doubler to insert
on the inside of the hole. You just turn the doubler sideways, and slip it
in through the oval - not possible with a round hole.
---------------------------orig.-----------------------------------------
*----------------------------------------------------*SCOTT
electrical panels.
LisaFly99
BOB
That oval hole trick sounds like the way to go. Wish I had that knowledge
four years ago.
Phil&Lisa Smith #460 N414D
four years ago.
klehman
Scott
Probably so obvious that it doesn't need mentioning, but one of those drum
sanding
attachments for a drill (about 2 inches or so diameter) will save a lot of
filing after you rough cut the hole.
Also the hand nibbler that Wray mentioned is great for cutting slots. I got mine
on sale for about $12.
cheers
sanding
cheers
Joel Jacobs
Hi,
Check the link below - it's the slickest hole cutter I've ever seen. Works
beautifully after you get the hang of it.
http://www.wicksaircraft.com/showPage.phtml?pagenum=78
To: (Murphy Rebel Builders List) <murphy-rebel@dcsol.com>
Sent: Thursday, January 06, 2000 12:19 AM
Subject: Access hole cutting?
*----------------------------------------------------*What do you folks use to cut holes for access (like the access hole near
Kind Regards
Scott
hibbs@pacifier.com
