Thank for the advise. I will change them and put them inside.
Jean
Rebel 747R
On Sat Mar 4 22:50 , Ken <klehman@albedo.net> sent:
Jean
If you are talking about the interior corner wraps that go from the
floor to the side walls then I'd keep what you have already done and
rivet them together wherever the joints are.
For exterior corner wraps I think I'd want to join them at the bulkheads
as per the manual -unless the factory says it is OK to do otherwise and
you don't mind the slightly odd looking rivets. I guess if you have
enough overlap to put two rows of rivets at the joint then standard
repair practice probably says it is OK to join them anywhere the joint
is. That is the impression I get from AC43.13 anyway.
Jean Poirier wrote:
The top wrap are not fix yet... but the bottoms ones are done! The splice
have not been done at the bulkhead intersection. Should I scrap the 2 raer
wraps or if I can splice them where they joint (they have 5/8"-3/4" overlap)
Jean
Rebel 747R
