[rebel-builders] electrical bus bars
Hi Mike
I ended up getting some from ACS as no one did it locally around here in
England
Nigel
745E
Jones, Michael
Sent: 03 March 2006 13:17
To: Rebel-Builders (E-mail)
Subject: [rebel-builders] electrical bus bars
hi all
does anyone know where in canada i can get copper material to use as bus bar
for my circuit breakers, looking for strips about 1/2" x 6" x 40-50 thou
thick, have found brass strips at local hobby store but no copper, or is
there something else to use ??
thanx
mike#007
England
Nigel
745E
Jones, Michael
hi all
thanx
mike#007
Hi Mike I slit a peice of copper plumbing pipe lengthwise and hammered it
flat.
flat.
Drewhi all
thanx
mike#007
hey drew
that has to be the most creative use of a pipe i have ever heard, thanks for
the idea
mike#007
Sent: Friday, March 03, 2006 9:28 AM
Subject: Re: [rebel-builders] electrical bus bars
flat.
the idea
mike#007
flat.
barhi all
Drewfor my circuit breakers, looking for strips about 1/2" x 6" x 40-50 thou
thanx
mike#007
Should probably be "soft copper". The malleable ones will eliminate some
(not all) risk of craking! The malleable one is more expensive but for the
little qty you will need!
Jean
Rebel 747R
Sent: Friday, March 03, 2006 9:27 AM
Jean
Rebel 747R
flat.
At 08:17 AM 3/3/2006 -0500, you wrote:Drewhi all
bar
thanx
mike#007
Hi Mike
I think I have a piece of copper in my shop(somewhere.). I believe it is
.125 thick. I drilled it and tapped it for a bus bar. If you like I will cut
a piece and send it to you.
Dale 220 R
Dale 220 R
AFAIK brass is slightly preferable to copper but either will do. If you
don't have it by the next meeting I can cut you some brass strips.
hi all
thanx
mike#007
Hi Ken, I will need something within the next couple of months, so if
you had a little to spare, I could certainly use it.
Jim
Rebel 333
Jim
Rebel 333
hi all
thanx
mike#007
OK Jim
I have a sheet of it but it is a bit of a bear to cut even with a
bandsaw so I'll try to remember to cut a few at the size Mike mentioned
unless you tell me otherwise or want to wait until you plan your panel.
Jim
Rebel 333
hi all
thanx
mike#007
