[rebel-builders] Engine Primer
Posted: Sun Feb 19, 2012 1:30 pm
by Jones, Michael
mike
primer, yes, not to say bad word but all cessna,s i have seen have primers,
maybe some makes don't but on some days don't know how you would start a
0-320 without a primer
as for baffles, vans sells a kit for 0-320 that a lot of people use and i
have bought, its a great kit
mike#007
indabush@hay.net
Sent: Thursday, March 02, 2006 11:38 AM
To: rebel-builders-d@dcsol.com
Subject: [rebel-builders] Engine Primer
At the risk of asking a dumb question ..................................
O-320 E2D, no fuel pump
I had not planned on installing an engine primer, but now I am not so
sure. Since most of my flying is in helicopters, I am not totally into the
Lycoming world yet. What is the consensus out there?
Also, I am looking for a set of baffle cutting templates for this engine.
I looks like it will be a lot of work to make templates from scratch.
Mike.
_____________________________
Mike Ash, 305R
by WALTER KLATT
Also, while I'm not 100% sure about this, but when changing fuel tanks or turning on my tank valves (top ones by the tanks), or after draining the gascolator for water, there may be the possibility of some trapped air in the top of the gascolator. The reason I say this, is that I have noticed sometimes when I use the primer before starting the engine, that it takes a few pumps before I feel it pumping fuel. So it seems to be purging the air out first. Like I said, though, could be wrong here, and maybe it is just that it takes a while for the primer O ring to seat enough to start pumping.
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
Date: Thursday, March 2, 2006 8:44 am
Subject: RE: [rebel-builders] Engine Primer
mike
primers,maybe some makes don't but on some days don't know how you
would start a
use and i
mike#007
From: mike.davis@dcsol.com [mike.davis@dcsol.com]On Behalf Of
indabush@hay.net
so
into the
engine.
Mike.
Mike Ash, 305R
Remember that underwear darkening COUGH on take off one day Walter?? That
was from the air in your gascolator after you had drained it and not used
the primer to remove the air!
That gives another reason to have one for sure....although, Mike, I wish you
luck starting that lycoming on a cold winters day without a primer...and if
you're going to do it right prime all 4 cylinders for even start/wear....or
at least three if you need a vacuum pick up for a manifold pressure gauge or
sensor like the EIS system.
Sent: Thursday, March 02, 2006 1:48 PM
Subject: Re: RE: [rebel-builders] Engine Primer
mike
would start a
use and i
mike#007
indabush@hay.net
so
into the
engine.
Mike.
Mike Ash, 305R
by WALTER KLATT
Yes, I do rememer that one very well (surprised you did), but that was after refueling and switching tanks, after filling an empty one. If you recall, I had found that with my fuel set-up (shut off valves up top) that if I close the empty tank before opening the new one, I will create an airlock in my fuel lines. I can repeat and demonstrate that one at will now. If I did that in the air, it would result in an engine outage. Now in hindsight, and thinking about air in the gascolator, maybe the primer would clear that airlock. Will have to try that when I get a chance (on the ground of course).
And then there was that other wierd one if you remember, where I had dirt in my primer, and it caused fuel to get sucked by into my cylinders. Took me a while to find that one (your expert remote diagnosis was right on again, though) and had quite a few engine stumbles at inopportune times, including with a passenger one time at the lake. First time I have ever seen anyone grab for the window of an airplane in flight, like she wanted out. Not sure what she was thinking there, but got her calmed down OK and we cruised back at a low power descent for an uneventful landing back at my cabin. Went through some extra booze that evening, and no more rides that weekend...
Date: Thursday, March 2, 2006 2:46 pm
Walter?? That
not used
I wish you
primer...and if
start/wear....orat least three if you need a vacuum pick up for a
tanks or
draining the
air in
noticedsometimes when I use the primer before starting the engine,
that it takes a
the air
is just
start pumping.
mike
would start a
use and i
mike#007
indabush@hay.net
so
into the
engine.
scratch.> >
Mike.
Mike Ash, 305R
by Keith Leitch
Walter,
Are you refering to airplane rides?
off one day
Walter?? That
drained it and
not used
I wish you
without a
primer...and if
for even
when changing fuel
tanks or
or after
draining the
of some trapped
air in
is that I have
that it takes a
seems to be purging
the air
here, and maybe it
is just
seat enough to
start pumping.
there?
templates for this
templates from
scratch.> >
Unsubscribe:
=== message truncated ===
Do You Yahoo!?
http://mail.yahoo.com
by Walter Klatt
Yes... And no, it was not the wife, but another friend.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Keith
Leitch
Sent: Thursday, March 02, 2006 4:37 PM
Walter,
off one day
Walter?? That
drained it and
not used
I wish you
without a
primer...and if
for even
when changing fuel
tanks or
or after
draining the
of some trapped
air in
is that I have
that it takes a
seems to be purging
the air
here, and maybe it
is just
seat enough to
start pumping.
there?
templates for this
templates from
scratch.> >
Unsubscribe:
Do You Yahoo!?
