[rebel-builders] Re: Landing Gear-Brakes
Post by Wayne G. O'Shea » Sun Feb 19, 2012 1:27 pm
A 1 inch uni-bit or greenlee bit would be best. I'm gonna put my boots on
and hit the shop to look at the three sets of matco's I have out there and
will be back.
Sent: Tuesday, February 28, 2006 8:48 PM
Subject: [rebel-builders] Re: Landing Gear-Brakes
I ran into another issue this evening and I was wondering if I'm missing
something?
The caliper mounting plate (Matco) that slides over the axle to be
attached to the flange - on the axle - only goes as far as the ridge or
increase in diameter of the axle from 3/4 to 7/8. Am I missing
something? I feel the hole in the caliper mounting plate should be 7/8
and slide right to the flange and that the ridge is for the bearing to
butt up against?? I don't have a 7/8 inch drill - any suggestions?
Jim
Rebel 333
