[rebel-builders] Rebel Elevator/ web log
Posted: Sun Feb 19, 2012 1:26 pm
Sent: Friday, February 24, 2006 9:22 AM
Subject: Re: [rebel-builders] Rebel Elevator/ web log
Hi Brian!
From reading the list I learned that it is not necessary to beef-up the
rudder ---- although I did, I made pie-doublers flush riveted under the
skin on the horn end and the full mod on the tip end, as. I made a new more
rounded rudder tip with tail light - it came out a bit heavy for my taste
and I still have to check with MAM if it is accptable.
My weblog with pics can be found at
http://www.mykitlog.com/users/index.php ... project=33 if
anyone is interested....
gx from the Alps
Dieter
778R
PS
glad MAM bashing has stopped and to read all the support mails. From my
work
as an animal-doc I know that one angry bull does more harm than hundred
satisfied cows ;-))
Hi Brian!
gx from the Alps
Dieter
778R
PS
work
satisfied cows ;-))
Sent: Thursday, February 23, 2006 5:56 AM
Subject: [rebel-builders] Rebel Elevator
Ahoy all!
Just finished the elevator mod to prevent skin flexing/cracking at the
outer end of the spar as per the photos in the archives.
Question. Is there a valid reason, or need, to apply the same mod to the
Rudder Horn? Or is it a waste of time to do it because there is no lead
weight in that horn?
Thanx all
Brian R779
