[rebel-builders] sanding paint off of fiberglass
Posted: Sun Feb 19, 2012 1:22 pm
If anybody has an M14 mount on order or recently received one, you need to
check with the factory on the status...
Both the mounts in the Chilliwack shop don't fit. On one the mag is too
close, but on the other you can't get one of the mags on!!!
Doug took it back and after the usual agrivation, they agreed to cut and
reweld it.
Also, don't bother with that little plastic fish tank pump for the clean
kit...just order a Facet from Aircraft Spruce.
Scan and help eliminate destructive viruses from your inbound and outbound
e-mail and attachments.
http://join.msn.com/?pgmarket=en-ca&pag ... S_Taglines
Start enjoying all the benefits of MSN
reweld it.
_________________________________________________________________From: Jason Beall <super_rebel131@yahoo.com>
To: new list server <rebel-builders@dcsol.com>
Subject: [rebel-builders] sanding paint off of fiberglass
Date: Mon, 20 Feb 2006 05:27:57 -0800 (PST)
Hi all,
Can anyone recommend the correct procedure to sand
paint off of fiberglass? Is it ok to use a power
sander? If sand paper is to be used, what grit?
Thanks.
Also, Nigel or any of the other guys in the UK: Does
anyone know of a decent place to get a PFA type
resprayed without braking the bank?
SR131 is coming along. Doors are finished and now
working on the windows. At this rate I have her flying
by retirement. For those that know me, that's a LONG
way off!
Regards, -Jason
Do You Yahoo!?
http://mail.yahoo.com
