Just received one of Dale's tail springs, and it is superb. Beautifully
machined, has the bend in the right place so the pivot bolt is
verticle....but also IT HAS ALL THE HOLES DRILLED.
So you don't have to try and drill into hardened steel, using the soft
aluninum swivel as a guide, and try to keep all the holes in the same plane.
The stinger fits Dale's titanic tail spring brackets (two bolts), or the
standard Murphy bracket (one bolt).
It is also very inexpensive.
If your Moose ain't on floats, get one.
Brian
Designer Mail isn't just fun to send, it's fun to receive. Use special
stationery, fonts and colors.
http://join.msn.com/?pgmarket=en-ca&pag ... S_Taglines
Start enjoying all the benefits of MSN
