Hydraulic flaps
Jesse Jenks
Hydraulic flaps
Post by Jesse Jenks » Sat Feb 18, 2012 2:53 pm
Has anyone considered using the hand operated hydraulic pump for amphib gear
to power a hydraulic actuator for the flaps as well? You could pump the
flaps up and down like a Beaver. Sorry, I must be on a Beaver kick or
something.
Jesse
Hydraulic flaps
Post by Drew Dalgleish » Sat Feb 18, 2012 2:53 pm
I think it would be a plumbing nightmare to install all the selectors you'd
need to use the same pump for both flaperons and landing gear. I've given
some thought to using a simple hydraulic system with a master cylinder on
the roof and a slave moving the mixer up and down. This would solve the
problem of slop in the teleflex cable but I don't think it would work to
reflex the flaps. So you could add a big spring to lift the flaps but then
it might take too much effort to lower them. So my personal solution is as
usual to do nothing The teleflex cable works sort of OK and if I want to
come down right now a full forward slip can get me a descent of over 2000fpm.
something.
Jesse
WALTER KLATT
Hydraulic flaps
Post by WALTER KLATT » Sat Feb 18, 2012 2:53 pm
While many have complained about the slack in the stock system, this is not an item that I would change if I was building again. First, the only time I really needed full flap on my Rebel was for amphib take-offs both on water and land, and the stock system did the job just fine. Landings are just half flap. The stock system also works well with reflex. The only nice change would be the dog leg handle, but I don't even have that on mine. On wheels, you seldom need full flap, but they do really work if you want to drag it in with a little power to a short field. Should be no problem in coming to a stop in 400 feet or so, if you really want to. Take-offs on land for me were always faster than landing, so that was never an issue (with an 0320).
Remember, too, that these things all add weight, cost, and time, so you need to pick and choose which mods are really necessary. Unless you like building more than flying...
JMHO
Date: Monday, February 6, 2006 12:46 pm
Subject: Re: Hydraulic flaps
selectors you'd
I've given
cylinder on
solve the
work to
but then
solution is as
want to
over 2000fpm.
amphib gear
pump the
kick or
something.
Jesse
Jesse Jenks
Hydraulic flaps
Drew and Walter,
Thanks for the input. You're cautions against adding complexity and weight
are noted, and I am only looking at this as a far-out possibility. As a
theoretical thing, it's still an interesting idea to me.
Wouldn't it be possible to just add another hydraulic "circuit" coming out
of the pump? The flap selector would need to have a neutral position that
would allow pressure to return to the reservoir while locking pressure in
both sides of the flap actuator. This way you could run the the gear without
moving the flaps. When running the flaps, pressure would also go to the
gear, but would only act to hold the gear in the selected position.
Alternatively, you could use a gear selector with a neutral position as
well.The Piper Navajo has a gear selector that returns to neutral
automatically when hydraulic pressure reaches a certain value after gear
extension or retraction, allowing fluid to circulate continuously in the
system. That system uses two engine driven pumps that obviously run whenever
the engines do, which is most of the time in my experience.
With a two way actuator wouldn't it be simple to get reflex? If you have the
pump mounted between the seats, wouldn't it be a pretty easy plumbing job to
route lines over to the left side to an actuator attached to the mixer arm
in the same location the teleflex would? If you wanted the selector on the
instrument panel, that would be more lines of course, but it seems like
there wouldn't be much of a net weight change. An actuator, lines and
selector, a bit more fluid. You would shed the teleflex, flap handle, and
reinforcements to the roof.
A position indicator would be an integral part of the system because the
flap angle would be infinitely adjustable and would not have any "notches".
You could make a simple indicator on the instrument panel using a small
diameter flexible pushrod (a model airplane pushrod would work) from the
mixer arm to the indicator.
Oh well, that's the kind of thing I think about to keep myself awake when
driving to work at 4:00 am.
Jesse
Date: Mon, 06 Feb 2006 15:53:49 -0800
(with an 0320).
JMHO
selectors you'd
I've given
cylinder on
solve the
work to
but then
solution is as
want to
over 2000fpm.
amphib gear
pump the
kick or
something.
Jesse
Hydraulic flaps
Post by Ken » Sat Feb 18, 2012 2:53 pm
Unfortunately there have also been fatal crashes from sudden uncommanded
manual hydraulic flap retraction as well. At least one that I know of in
an early model Otter which I think is very similar to the Beaver system
that you mentioned. IIRC the redesign involved the $elector valve, a
mechanical elevator trim tab linked to the flaps, and pilot procedure.
Even the expert$ have messed this up so it may not be real simple to do
it safely.
Jesse Jenks wrote:
Drew and Walter,
Jesse
Hydraulic flaps
Post by Bob Patterson » Sat Feb 18, 2012 2:53 pm
Hi Jesse !
If you want something to keep you awake on those early morning
drives - get a copy of the early Oshkosh Tower Tape ! A few minutes
of that, and I'm wide awake and looking all over the place to try to
see that "yellow Piper coming up on the outside ..." !! :-) :-)
I didn't know there WAS a 4 o'clock in the Morning - in fact,
was quite surprised to discover there were TWO " 9 O'clocks" !! ;-)
(Don't usually get up until "the crack of noon" !) ;-) :-)
On Monday 06 February 2006 09:13 pm, Jesse Jenks wrote:
Drew and Walter,
weight are noted, and I am only looking at this as a far-out possibility.
As a theoretical thing, it's still an interesting idea to me.
out of the pump? The flap selector would need to have a neutral position
that would allow pressure to return to the reservoir while locking
pressure in both sides of the flap actuator. This way you could run the
the gear without moving the flaps. When running the flaps, pressure would
also go to the gear, but would only act to hold the gear in the selected
position. Alternatively, you could use a gear selector with a neutral
position as well.The Piper Navajo has a gear selector that returns to
neutral automatically when hydraulic pressure reaches a certain value
after gear extension or retraction, allowing fluid to circulate
continuously in the system. That system uses two engine driven pumps that
obviously run whenever the engines do, which is most of the time in my
experience.
the pump mounted between the seats, wouldn't it be a pretty easy plumbing
job to route lines over to the left side to an actuator attached to the
mixer arm in the same location the teleflex would? If you wanted the
selector on the instrument panel, that would be more lines of course, but
it seems like there wouldn't be much of a net weight change. An actuator,
lines and selector, a bit more fluid. You would shed the teleflex, flap
handle, and reinforcements to the roof.
"notches". You could make a simple indicator on the instrument panel
using a small diameter flexible pushrod (a model airplane pushrod would
work) from the mixer arm to the indicator.
Jesse
JMHO
selectors you'd
I've given
cylinder on
solve the
work to
but then
solution is as
want to
over 2000fpm.
At 03:39 PM 2/5/2006 -0800, you wrote: amphib gear
pump the
kick or
Al Paxhia
Hydraulic flaps
Post by Al Paxhia » Sat Feb 18, 2012 2:53 pm
Hi Jesse,
I have a little Beaver time and I like the hydraulic flaps but in the 570
Moose hours I like the teleflex setup I have better. In the Beaver if the
selector position is manual and I have to remember to put it in the down
position every time the flaps are moved, otherwise the flaps can go the
wrong way. There have been many times when I have used the flaps with gusto.
With the Johnson bar the flaps go in or go out just as fast or slow as
needed to get the job done, there is no mistake, pull bar flaps down,
release bar flaps up. IMHO the mechanical flaps are the best solution for
the Moose. If you must stay awake at night, figure out how to get it built
faster, it's a lot more fun flying it than building, but that's me.
Al
Moose N526AP
Sent: Monday, February 06, 2006 6:45 PM
it safely.
Jesse Jenks wrote:
Drew and Walter,
without
whenever
"notches".
Jesse
