fluting pliers/shrinker-stretcher/wing ribs
N.Smith
Post by N.Smith » Sat Feb 18, 2012 2:45 pm
I too have the problem with the root ribs and No4 fuel bay solid rib being
twisted. The flange is not the problem however, as all flanges have been
removed on the extra root nose ribs that act as doublers, and the twist
remains in them as well.
This only affects the solid ribs, all other ribs with lightening holes/areas
are fine.
I'm going up to our airframe workshop this weekend so as soon as I find
someone who can solve this easily I'll post their solution.
Nig
745e
skype: airnig
lawsondj@comcast.net
Sent: 21 January 2006 06:41
Subject: RE: fluting pliers/shrinker-stretcher
Only problem with the fluting pliers is you have to avoid the plier
indenations when laying out the rivet holes whereas the shrinker leaves a
flat surface to rivet against.
Jack, SR193
I spent a pleasant afternoon sitting on the deck with my fluting pliers
a pile of ribs and had no trouble getting them straight that way. I have a
shrinker/stretcher as well and have not found it to be very useful. You
could do it with either tool, but I think the fluting pliers are a lot
easier and works just fine.
In answer to Mike Jones question, I assume Keith's ribs are not straight
as
a result of the manufacturing process that created the flange. That gives
them a bit of a curve that needs to be removed. Again, an easy process
with
the pliers.
Keith
Leitch
Sent: Friday, January 20, 2006 11:34 AM
To: Murphy Rebel Builders
Subject: fluting pliers/shrinker-stretcher
I am trying to get the ribs straightened out so they
are level. What is best to use to form them to be
level? I have a shrinker/stretcher, or should I use a
fluting plier?
Keith R661
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Keith Leitch
Post by Keith Leitch » Sat Feb 18, 2012 2:45 pm
The twist is what I'm talking abot. I spent quite a
bit of time trying to get one of the solid fuel bay
ribs flatter and couldn't. If you find out the trick
please let me know.
Keith
are fine.
solution.
Nig
745e
skype: airnig
avoid the plier
Jack, SR193
as
with
the pliers.
Keith
Leitch
they
use a
fluting plier?
Keith R661
Do You Yahoo!?
protection around
Do You Yahoo!?
Jesse Jenks
Post by Jesse Jenks » Sat Feb 18, 2012 2:45 pm
Keith,
I don't think it is possible to remove the twist, in fact they get worse
when you start pounding on them to make flat spots for the fuel fittings,
but don't worry, as you build the wing and cleco the skins on the solid
ribs, they will straighten out.
Jesse
Subject: RE: fluting pliers/shrinker-stretcher/wing ribs
Date: Sat, 21 Jan 2006 09:51:54 -0800 (PST)
please let me know.
Keith
are fine.
solution.
Nig
745e
skype: airnig
avoid the plier
Jack, SR193
as
with
the pliers.
Keith
Leitch
they
use a
fluting plier?
Keith R661
Do You Yahoo!?
protection around
Do You Yahoo!?
Keith Leitch
Thanks Jesse. That was one of my options but, I was
worried about it causing a wrinkle in the wing skin if
I did that. You are right...the more I tried
straightening them the worse they seemed to get.
Keith
--- Jesse Jenks <jessejenks@hotmail.com> wrote:
Keith,
fact they get worse
skins on the solid
Jesse
ribs
trick
please let me know.
Keith
No4
as
are fine.
weekend
their
solution.
Nig
745e
skype: airnig
avoid the plier
whereas
Jack, SR193
deck
and straight that way. I have a
it
to be very useful. You fluting pliers are a lot
Keith's
as
created
removed.
with [mailto:mike.davis@dcsol.com] On Behalf Of
Keith
so
they
be
use a
protection around
=== message truncated ===
Do You Yahoo!?
Post by Mike Kimball » Sat Feb 18, 2012 2:45 pm
To get the not-quite-straight ribs clecoed in place with the skin I would
get one hole located using a rivet held upside down using the mandrel and
then work each of the next holes in place dropping upside down rivets into
place, mandrel first, into each hole as I worked the rib into place. Even
if you can't see the next hole, you can use the mandrel to work the rib a
bit at a time until you do see the hole. Sometimes I would have to poke a
long dowel through somewhere if there was access to push on the rib to get
things started. I would sometimes use one rivet mandrel in one hand to sort
of pull the rib a bit then use another one in the other hand through a
different skin hole to hold things while I worked the rib until I could drop
the rivet mandrel into the hole. Don't put any clecoes in until the entire
rib is located with upside down rivets. You can even get a bit of rib
movement by pushing on an upside down rivet that is already in a hole.
There was no skin wrinkling problem with my wings.
044SR
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Keith
Leitch
Sent: Saturday, January 21, 2006 11:58 AM
Keith
Keith,
fact they get worse
skins on the solid
Jesse
ribs
trick
please let me know.
Keith
No4
as
are fine.
weekend
their
solution.
Nig
745e
skype: airnig
avoid the plier
whereas
Jack, SR193
deck
it
Keith's
as
created
removed.
Keith
so
they
be
use a
protection around
Do You Yahoo!?
N.Smith
The word from all the guys in our airframes workshop is that the shape makes
the use of any stretcher very difficult. The best solution would also
involve heat treating, and in the end they all reckon simply using the skins
to pull them straight is going to be the best option, since they are of such
thin sheet.
Glad the easiest way seems to be the way to go.
Nig
745E
Keith Leitch
Sent: 21 January 2006 17:52
please let me know.
Keith
are fine.
solution.
Nig
745e
skype: airnig
avoid the plier
Jack, SR193
as
with
the pliers.
Keith
Leitch
they
use a
fluting plier?
Keith R661
Do You Yahoo!?
protection around
Do You Yahoo!?
Jean Poirier
Post by Jean Poirier » Sat Feb 18, 2012 2:45 pm
Phew!
I have made both wings without try to make any "reforming" work on solid
rib! When you guys asked the best way to make them straits.... I have
thanks That I have made a bad job! Happy to know that is was ok!
Jean
Rebel 747R
Sent: Monday, January 23, 2006 6:22 AM
makes
skins
such
thin sheet.
Nig
745E
Keith Leitch
please let me know.
Keith
are fine.
solution.
Nig
745e
skype: airnig
avoid the plier
Jack, SR193
as
with
the pliers.
Keith
Leitch
they
use a
fluting plier?
Keith R661
Do You Yahoo!?
protection around
Do You Yahoo!?
