Elevator Trim over-ride
Has anyone with a flying Super Rebel / Moose ever ran the elevator trim
servo to it's limits in flight to see how hard it would be to over-ride a
runaway or broken trim servo? A conversation with Scott at Ray Allen got me
thinkin'. He wants me to trade in my MAC-8A servo for the newer, and
supposedly better constructed T3-12A servo. He also thinks that my plan to
use a T2-7A servo to move the aileron pivot block on the roof for aileron
droop is ambitious. He's afraid that the servo will be working too hard to
overcome aerodynamic forces on the block and will fail. Any opinions on the
aerodynamic forces acting on the block? Operationally, I will most likely
be in level flight whenever I am making changes to the droop. I.e., I'll be
deciding and setting the droop based on conditions while on downwind. That
also made me think about the fact that I have separated the aileron droop
function from the flaps. There has been some concern that it will be a
muscle man pull on the flap lever with my roof mounted system. At least I
have removed any force on the block that the ailerons might induce. Food
for thought.
for thought.
Brian Godden
Mike....it is impossible to override a full nose down position of the trim
in a Moose. Tried it during testing...very scary. Bob is absolutely correct
when he says fit a breaker and highlight it in red.
Brian
Scan and help eliminate destructive viruses from your inbound and outbound
e-mail and attachments.
http://join.msn.com/?pgmarket=en-ca&pag ... S_Taglines
Start enjoying all the benefits of MSN
Brian
_________________________________________________________________From: Mike Kimball <mkimball@gci.net>
To: Rebel Builder's List <rebel-builders@dcsol.com>
Subject: Elevator Trim over-ride
Date: Thu, 19 Jan 2006 20:08:35 -0900
me
be
for thought.
Dale Fultz
Thanks for stepping in here finally and giving us some good feedback that we
all need. Thanks again Brian. Dale SR-033 Back to riveting
Then the question begs to be answered...does anyone use the full travel of
that HUGE trim tab in normal flight envelopes? The trim tab on my 4200lb
gross UTVA's is about 1/2 that size if that.......and I'd have a hard time
shoving the stick forward in that if it got stuck at even 1/2 travel nose up
and I wasn't coming into land immediately.
Sent: Friday, January 20, 2006 10:07 PM
Subject: Re: Elevator Trim over-ride
weThanks for stepping in here finally and giving us some good feedback that
Robert and Olga Johnson
I was really surprised to see this response and find it hard to believe if
this condition exists, that Murphy would not caution builders and/ or build
in a limiting stop. When I first flew my Rebel I checked full travel of the
trim in both directions to make sure I could still maintain control should a
trim runaway occur. - No problem with the Rebel, although I would be landing
as soon as possible.Thank God ( I mean Mike) that this site exists so we may
all learn and hopefully avoid this potensionally disastrous condition. Just
my $0.02 Cdn worth. Bob J
Sent: Friday, January 20, 2006 9:37 PM
Subject: RE: Elevator Trim over-ride
correct
Brian
Brian Godden
Good question Wayne...compare the Elite elevator (identical, just smaller)
and it's trim tab. The Elite's trim is much smaller in chord, and no problem
to override. Trouble is the spades are too big!! You do need almost full
nose up trim in a radial Moose during approach, but builders should limit
the nose down travel....from memory I just set it at 6 degrees.
_________________________________________________________________From: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
Date: Sat, 21 Jan 2006 00:35:13 -0500
up
thatThanks for stepping in here finally and giving us some good feedback
weall need. Thanks again Brian. Dale SR-033 Back to riveting
CWS1932
To prevent a runaway trim (elevator and rudder) I installed red-guarded
cut-off switches to disable trim system in event of a runaway (removes power from
the trim system). Same type systems used on 727's, etc.
Charlie Starr SR-2500
I don't mean to "rain"...but I doubt anyone will get a breaker pulled or
switch shut off in the time period it takes to go full travel on the trim
and you've figured out WTF is going on.
Flight test..find trim limits you can man handle...and then set the servo
limits to match.
Sent: Saturday, January 21, 2006 10:40 AM
limits to match.
power from
Bill Delcambre
It happened to me during climbout in a 210. It just kept winding up...
You'd be amazed how fast you can think!
I like Wayne's idea a lot better, though.
Bill
Bill
limits to match.
power from
cut-off switches to disable trim system in event of a runaway (removesthe trim system). Same type systems used on 727's, etc.
Keith Kinden
One simple answer to the trim problem is a double switch. I saw this done on
a customers airplane.
instead of the Mac rocker switch he used 2 toggle
switchs. one to run the Mac servo and one to power power the Mac switch.
pertty simple and quite fail safe, the chances of both switchs failing at
the same time are nill. For those who want the trim switch on the stick, you
could get a double rocker switch in place of your transmit switch, use the
down side for the radio and the upper for energizing the trim switch.
to operate the trim depress the power switch then move the trim switch.
Keith
CWS1932@aol.com
Sent: Saturday, January 21, 2006 8:41 AM
power from
Keith
CWS1932@aol.com
power from
N.Smith
For what it's worth, I plan to add a small audio source fed by the voltage
that feeds the servo, it will sound when ever the servo runs. If it runs
when I don't expect it I've got a red collar on the CB to trip it ASAP
Nig
745E
Bill Delcambre
Sent: 21 January 2006 17:00
Bill
Nig
745E
Bill Delcambre
Bill
limits to match.
power from
I'll have to have another look at the servo. I didn't realize that the
limits are adjustable. Problem is, the servo is attached to the elevator
which is at my unheated hangar at the airport and it's 20 below during the
day. I don't wanna go look right now.
G. O'Shea
Sent: Saturday, January 21, 2006 7:33 AM
limits to match.
G. O'Shea
limits to match.
power from
Pretty darn sure if you open the cover you can adjust the stops that hit the
limit switches.
Sent: Saturday, January 21, 2006 8:56 PM
limit switches.
WayneI'll have to have another look at the servo. I didn't realize that the
G. O'Shea
limits to match.
power from
