Rebel Rudder pedals:
Alvin and Glenys Adams
Post by Alvin and Glenys Adams » Sat Feb 18, 2012 2:37 pm
read you postings with great interest as i am about to install nico press on my elevator cables.I assumed i would rig cables to have stick in comfortable position with elevator level with stabilizer.This was the case with my PA-11.Al says he flies level flight on floats with 10 degree up elevator.Why would a aircraft be designed like this.Hope mine will not be like this.Seams sort of inefficient.Should i set up for comfortable stick at o degrees or 10 degree up.
Alvin Rebel 776.
Robert and Olga Johnson
Post by Robert and Olga Johnson » Sat Feb 18, 2012 2:37 pm
Alvin, I would definitely set elevator at 0 degrees with a comfortable stick
position. My Rebel flew basically hands off on neutral trim position with an
O320 up front and original firewall position. I did not (yet) have a chance
to float equip a Rebel, but if rigged and balanced properly this should not
change. All you float drivers out there should be able to shed some accurate
data on this.- Bob J
From: "Alvin and Glenys Adams" <gander.electrical@nf.sympatico.ca>
To: "rebel" <rebel-builders-d@dcsol.com>
Sent: Wednesday, January 04, 2006 3:55 PM
Subject: Rebel Rudder pedals:
Alvin Rebel 776.
Schmucker, Del
Post by Schmucker, Del » Sat Feb 18, 2012 2:37 pm
On floats I don't know whether there is any additional up elevator if
there is I don't notice it on ski's in the winter. Realize that 10
degrees on the elevator is not very much stick movement.
Thank you,
Del Schmucker
Information Systems Manager
807-223-1254
807-221-8769 Cell
807-223-4703 Fax
del.schmucker@kpdsb.on.ca
www.kpdsb.on.ca
Sent: Wednesday, January 04, 2006 2:55 PM
To: rebel
Alvin Rebel 776.
Rebel rudder pedals:
Thanks for the input guys.Just finished elevator set up.Set elevator slightly up with stick in neutral.Anyone every used a straight stick.Looks like it would work better for me.Have 160 with firewall not cut back.Stabilizer set at .7 as per waynes suggestion.Will rig rudder tomorrow night.
Alvin 776R
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:37 pm
You'd have problems with stick hitting the panel Alvin...as 776 has the
desensitized mixer in the tail and you'll have 18" of stick throw to get
what you want in elevator travel. Probably could go with the older 2" stick
offset if you limit the down elevator stop to keep the stick off the panel
(full left and foward is worse).
Sent: Wednesday, January 04, 2006 8:50 PM
Subject: Rebel rudder pedals:
night.
Alvin 776R
