Rebel SPIN tests with leading edge cuffs on
Posted: Sat Feb 18, 2012 5:33 pm
G'day Everyone !!!
Does ANYONE know how our Rebels behave in a SPIN Test - with leading edge cuffs on the wings ?????
(doing a bit of research "down here"
MERRY CHRISSY everyone !!!
From Rick & Wendy Harper
541R
Sent: Wednesday, December 21, 2005 11:44 PM
Subject: Re: Rudder fairleads
Mike, on going through these bulkheads, yes you do. I liked somebody's idea
about using a laser pointer and a plastic dummy bulkhead to align the holes,
but I had the permaent bulkhead already in place before I takled this
problem. There's no perfect alignment, beacuse movement of the rudder horn
attach point means that the cable is always going to be dragging sideways on
the most aft fairlead at some point in its travel, unless the holes in the
bulkhead and fuselage side are enormous. I actually wound up placing a
fairlead at the aft end of the slot through the fuselage skin to keep things
aligned. I'd prefer less fairleads as there's quite a bit of drag in the
system, especially with water rudders added.
541R
