SR/Moose Rudder deflection
jtpackard
Post by jtpackard » Sat Feb 18, 2012 2:30 pm
Question for those flying a SR or Moose. I'm just about to rivet the rudder deflection stops in place. Has everyone put the stops in for 25 deg max ? and would you recommend staying with that or increasing or decreasing it some amount?
Tom Packard
SR043
--- http://USFamily.Net/dialup.html - $8.25/mo! -- http://www.usfamily.net/dsl.html - $19.99/mo! ---
Post by Mike Kimball » Sat Feb 18, 2012 2:30 pm
I don't have an opinion about whether 25 degrees is the right amount but I
do have a related comment. I put my rudder stops on for 25 degrees using
just the rudder. I made the mistake of just assuming the elevator would
have the proper clearance for 25 degrees since that is what MAM recommends.
Wrong. I ended up moving the elevator ribs and cutting the elevator skins a
bit to open it up enough to get 25 degrees from the rudder without hitting
the elevator. Might want to check that. If you have a clearance problem
like I did then your decision will be whether to do what I did or accept
less than 25 degrees rudder deflection.
jtpackard@usfamily.net
Sent: Thursday, December 08, 2005 10:28 AM
Subject: SR/Moose Rudder deflection
some amount?
Tom Packard
SR043
Scott Aldrich
Post by Scott Aldrich » Sat Feb 18, 2012 2:30 pm
I put the stops in after the elevator was on and just went with max throw
leaving clearance for the elevator. Don't really know what it is in
degrees.
Scott
Sent: Thursday, December 08, 2005 12:28 PM
some amount?
Tom Packard
SR043
jtpackard
Thanks Mike and Scott.
Mike, I did open up the elevator 'V' about 3/8" on each side - Cut the
skins back to the inside of the original rivet holes. I'll have to assemble
the stab & elevator and see if there is still interference. Then I think I
will go with Scott's approach and set the rudder up to whatever the geometry
allows.
Tom Packard
SR043
Sent: Thursday, December 08, 2005 1:51 PM
Subject: RE: SR/Moose Rudder deflection
recommends.
rudder
some amount?
Tom Packard
SR043
