Page 1 of 2
Rebel Wing Tips
Posted: Sat Feb 18, 2012 5:29 pm
by Jesse Jenks
Jeff,
I would like to see more pictures. Thank you. Your plane looks great by the
way. Maybe you could give us some performance numbers to compare with Rebels
using Fife tips.
I have planned to put the strobe power packs in the wings with access
through the tip for maintenance or replacement. I might have to rethink that
if I use the droop tips.
I have done a little google searching on wing tip design, and there are
definitely differing opinions on what works best. Some sources say tip
design makes little difference on low speed aircraft. An example given is
the Mooney. They are supposedly the most efficient light aircraft (not
including experimentals I'm sure) and they have squared off wing tips. I
know some of you swear by the Fife tips, but I would bet the performance
increases are mainly due to a bit more wing area over the standard MAM tips
so if the MAM droop tips add still more area they could be the best yet.
On the structural issue, if MAM is producing and selling these tips for the
Rebel then they must approve their use right?
Subject: Re: Rebel, Moose & Elite Wing Tips
Date: Sun, 04 Dec 2005 19:47:56 -0800
Jesse,
I installed these tips almost a 18 months after building the wings. Tips
were not available when the kit was purchased.
Spar extentions can be done at anytime.
Why would you want to get in a finished wing? (Drill rivets if you want
in, at this time in the build we should all be good at that:)
Yes, the spar ext and stringers are riveted to wing and tip with a stringer
splice/overlap.
Tips are available from MAM, droop tips are an ongoing production.
I'll try to dig up some more pics of tips being installed.
Jeff
Date: Sunday, December 4, 2005 6:58 pm
Jeff,
Can the mods to the spar and stringers be done if the wings are
already
finished? Also, how do the tips come off for accessing inside the
wing? Are
the spar and stringer extensions riveted to the wing and the tips?
Does anyone know if these tips are currently available?
I sent a request to MAM shipping as well.
Date: Sun, 04 Dec 2005 17:01:39 -0800
Jesse,
The clecos are holding my stringer splice, for my spar
extensions. Spars
extend into the wingtip aprox 8 to 10 inches.
Jeff
Date: Sunday, December 4, 2005 9:12 am
Rebel Wing Tips
by Ken
Tip design is probably more important on a 5 foot cord Hershey Bar wing
than on a Mooney tapered wing or even a single engine Cessna wing that
is partially tapered. There is an article on the net somewhere that does
a fairly detailed comparison of aftermarket tips on a single engine
cessna. IIRC the hoerner did significantly better than other designs. By
significant I mean a 2 or 3 knot change in cruise and/or stall speeds.
Jesse Jenks wrote:
Jeff,
using Fife tips.
Rebel Wing Tips
by Bob Patterson
Hi Jesse !
There is NO actual physical increase in wing area with the Fife
Hoerner tips - the factory insisted that they must be shortened to
the SAME length as the original factory tips, because of concerns
about increased bending load.
I understand that all later model Mooneys HAVE Hoerner tips,
and they are available as after-market add ons - must be a reason !
On the structural issue - the factory made these tips for
the MOOSE - I haven't seen anything that says they can be used
on a Rebel, cut down or otherwise. Of course, you can do as you
please - it is Experimental .... ;-)
Having flown my Rebel with both the standard tips and the
Fife Hoerner tips, I can say there DEFINITELY IS a performance and
handling improvement. There is better lateral stability, as the
Hoerner tip effectively adds a bit of dihedral. I would suspect
the opposite from the droop tips, as well as a bit less visibility
off the wing tip. There is also a definite reduction in takeoff
distance with the Hoerner tips - Curt has the real-world measurements !
And an improvement in low-speed handling, as well.
As Ken says, the numbers are relatively small - maybe 2-3 mph
reduction in stall speed, and 1-2 mph increase in cruise, but the
performance improvements are measurable and feel-able ! :-)
I would be interested in seeing the numbers for someone doing
the SAME tests Curt did, with droop tips of the SAME span. That
would tell the tale ....
Just my personal opinion - the Fife Hoerner wing & tail tips
are THE best bang-for-the-buck Rebel aftermarket add-on out there !!
Add in the McKenzie STOL kit of cuffs & fences, and you've got
outstanding STOL performance !! (..... and yes, maybe even those
NWA VGs like Pierre's Rebel - they do help....) :-)
(Of course, so does that tuned, balanced 195 HP IO-360 with the
Prince prop ! ;-) ) :-) :-) :-)
Just MHO - YMMD .... ;-)
.......bobp
On Monday 05 December 2005 11:46 am, Jesse Jenks wrote:
Jeff,
Rebels
using Fife tips.
that
tips
Jesse,
stringer
splice/overlap.
Jeff
Jeff,
already
wing? Are
extensions. Spars --- --- -- --
Rebel Wing Tips
by Bob Patterson
You're right, across the board, Ken ! My experience with the
Fife tips has shown exactly what you describe - improved lateral
stability, better recover from slips, and a tiny bit more speed.
The improved low speed stability was immediately noticeable.
Certainly, the climb performance and handling in turbulence
felt like increased wing span - it was much happier with TWO notches
of negative flapperon for cruise. (Presumable dumping more of the
surplus lift ...) :-)
.......bobp
On Monday 05 December 2005 07:59 am, Ken wrote:
Ahh you noticed why I asked! However the explanation may be that
Hoerner's effectively do add extra effective wingspan beyond their
physical dimensions. The lift on a 14" hoerner tip is probably just as
much as the lift on a 22" droop tip. If that is indeed the reason, it
makes me wonder why the factory didn't go to hoerners.
I believe an additional plus for hoerner's should be greater stability
as any sideslip may tend to lift the low wing more than other types and
probably slightly less profile and induced drag.
Bob Patterson wrote:
Hi Jeff !
Interesting ! I take it that the factory have changed their
position on tip length then ...... They specifically insisted that
Dave Fife make HIS Hoerner tips SHORTER - so they were no longer than
the original Rebel wing tips. This was to "reduce the extra load
on the wing resulting from increased span"..... or do they
recommend shortening the droop tips too ??? ;-^)
........bobp
On Sunday 04 December 2005 07:57 pm, Jeff McMurrer wrote:
Ken,
Droop tips are aprox 22 inches wide. They do add more to the wing area.
Jeff
Date: Saturday, December 3, 2005 5:14 pm
Rebel Wing Tips
by Jean Poirier
On Zenith web site, Chris Heinz have a good article on wing tip. Easy to
understand even for me ......
Jean
Rebel 747R
Sent: Monday, December 05, 2005 12:23 PM
Subject: Re: Rebel Wing Tips
Jesse Jenks wrote:
Jeff,
Rebels
using Fife tips.
that
tips
Rebel Wing Tips
by N.Smith
Hi Bob
I was sent a mail shot by MAM advertising the new tips when they came out,
and now have a set here for installation in my Elite when finished.
The MAM paperwork definitely quotes their use with Elite's. I'll check
tomorrow if it also says Rebel's.
Nigel
745E
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Bob
Patterson
Sent: 05 December 2005 18:18
Hi Jesse !
.......bobp
Jeff,
Rebels
using Fife tips.
that
tips
Jesse,
stringer
splice/overlap.
Jeff
Jeff,
already
wing? Are
Rebel Wing Tips
by Walter Klatt
Doesn't the Maverick have Hoerner style tips as supplied by MAM?
[mailto:mike.davis@dcsol.com]On Behalf Of Ken
Sent: Monday, December 05, 2005 9:23 AM
Hershey Bar wing
Cessna wing that
somewhere that does
single engine
other designs. By
Jesse Jenks wrote:
Jeff,
using Fife tips.
wings with access
An example given is
light aircraft (not
bet the performance
Rebel Wing Tips
by bransom
I'm looking forward to seeing the comparisons when they become available.
Perhaps the best of both worlds might be if Dave were able to eventually make
longer hoerner tips. HINT HINT :)
That said, I am interested to hear MAM's position on increased wing load. My
suspicion is that the plane might still calculate to the same design and
ultimate loads simply due to conservative margins in the original, but the
static load tests (and original flight tests for that matter) no longer
apply. One must be careful about design creep, and at some point with
greater wing area, the top of the green arc must also be changed.
-Ben
On 12/5/2005 9:23 AM, beep@sympatico.ca wrote to rebel-builders:
.......bobp
Hi Jeff !
........bobp
Rebel Wing Tips
by Rick Harper
Yep .... it's a pretty good explanation Jean !
For those of you who are interested ... here's the link http://www.zenithair.com/stolch801/design/design.html
(read the whole page too , people ! )
Rick
541R
Sent: Tuesday, December 06, 2005 6:17 AM
Jean
Rebel 747R
Jesse Jenks wrote:
Jeff,
Rebels
using Fife tips.
that
tips
Rebel Wing Tips
by Bob Patterson
Hi Nigel !
Thanks for the update ! I've heard from 2 people now that Murphy's
installation kit for the droop tips includes information about installation
on the Elite and Rebel, as well as the Moose.
They are OK for both kits, as long as the spar addition and
stringer extensions are added, so I guess the extra length is no problem.
These tips will be standard on the Yukon. Learning every day !! :-)
Would like to test-fly a set on a Rebel - maybe one day ....
Hope some of you out there beat me to it !!! :-)
Keep rivetting - it's worth it !!! :-)
On Monday 05 December 2005 02:23 pm, N.Smith wrote:
Hi Bob
Nigel
745E
Rebel Wing Tips
....well I know what to do with those extra 4 ribs and .020 sheet in the
shop now!!! LOL :O)
Sent: Monday, December 05, 2005 5:11 PM
Hi Nigel !
installation
Hi Bob
out,
Nigel
745E
Rebel Wing Tips
by Mike Betti
Nigel,
I would be interested in your information from MAM. I bought the droop tips
and don't know much about them.
You could email at mbetti@up.net if you like.
Mike Betti
771E
Sent: Monday, December 05, 2005 1:23 PM
Subject: RE: Rebel Wing Tips
Hi Bob
Nigel
745E
Patterson
Hi Jesse !
.......bobp
Jeff,
Rebels
using Fife tips.
that
tips
Jesse,
Tips
stringer
splice/overlap.
Jeff
Rebel Wing Tips
by Jesse Jenks
Bob,
I would like to join the Hoerner Team, but I havn't been able to get my
hands on any of Dave's so I was looking at plan B. I have a while before I
actually need them but I did want to complete the tip installation before
moving on to bigger and better things. Now I have another reason to
wait...to see how the MAM droopys compare.
Date: Mon, 5 Dec 2005 13:17:40 -0500
Hi Jesse !
.......bobp
Jeff,
Rebels
using Fife tips.
that
is
tips
Jesse,
Tips
want
stringer
splice/overlap.
Jeff
Rebel Wing Tips
by John Kramer
OK, I'm going to demonstrate, once again, how much I don't know.
I've been looking at various Chris Heintz designs all of which use a
Hoerner style tip fabricated of aluminum. The Sonex tip also is a
Hoerner style in metal. In looking at them the design doesn't seem
too difficult for hand tools and Zenith and Sonex plans builders
fabricate them from scratch. Why not sneak a look at a Zenith or
Sonex plan and adapt the metal Hoerner tip to the Murphy wing?
John...
Rebel Wing Tips
Been there..done that as I hate fiberglass with a passion. Bob P has one of
my sets collecting dust somewhere and another set went out on an AULA Rebel.
Sent: Tuesday, December 06, 2005 12:05 AM
John...
