Rebel Spar Caps
Posted: Sat Feb 18, 2012 5:29 pm
Good morning all.
As per the assembly manual, just pulled a rag soaked in "Tube Seal" through the rudder and elevator spars.
Pretty goopy stuff.
so I figure that when it comes time to chromate the spar ends that accept the spar caps, the added shear bonus of the chromate will be lost because of a less-than-perfect bond between the spar cap barrel, and the end of the spar, due to the oily "Tube Seal."
Any ideas on what to use to clean the "tube seal" just from the ends of the spar so that the chromate will bond to clean dry metal on the spar cap and the the end of the spar itself??
Thanx all
Brian
779R
Pretty goopy stuff.
Thanx all
Brian
779R
