O-320 cyl primer
rebelrick
O-320 cyl primer
Post by rebelrick » Sat Feb 18, 2012 5:23 pm
Hello,
Should the little engine primer fittings that solder to the primer lines
at the cylinder end be soldered with any special solder? Silver solder?
Rick
rebelrick
O-320 cyl primer
Hello again,
By the way, I am using 1/8" copper primer lines with the special primer
nozzles (brass)made for that use. I assume that with cyl head temps at a max
of 475*F, a 600* or so solder would be OK.
Rick
On 11/19/2005 8:41 AM, rebelrick wrote to all:
-> Hello,
-> Should the little engine primer fittings that solder to the primer
lines
-> at the cylinder end be soldered with any special solder? Silver solder?
-> Thanks,
-> Rick
O-320 cyl primer
Post by Wayne G. O'Shea » Sat Feb 18, 2012 5:23 pm
Yep, what ever you've got for solder. Most just use compression fittings
now...but nothing wrong with doing it "right"!
Sent: Saturday, November 19, 2005 12:46 PM
Subject: RE: O-320 cyl primer
Hello again,
max
Rick
-> Hello,
lines
-> Thanks,
-> Rick
O-320 cyl primer
Post by Walter Klatt » Sat Feb 18, 2012 5:23 pm
I still remember a long time ago when I did mine and ended up
using silver solder. Couldn't get the regular stuff to work.
Sent: Saturday, November 19, 2005 10:28 AM
Subject: Re: O-320 cyl primer
Hello again,
cyl head temps at a
max
Rick
-> Hello,
lines
-> Thanks,
-> Rick
O-320 cyl primer
Been away or something and playing catch up????...you Hawaiian bugger you!!!
LOL
Sent: Monday, November 21, 2005 11:16 PM
Hello again,
cyl head temps at a
max
Rick
-> Hello,
lines
-> Thanks,
-> Rick
O-320 cyl primer
Yup, been trying to skim through 300 emails here. You are sure a
prolific bunch, on the keyboard, that is.
Sent: Monday, November 21, 2005 8:19 PM
LOL
with the special primer cyl head temps at a
max solder to the primer solder? Silver solder? -------------------------------------------------------
